Running Pipes Through Floor/ceiling - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2016, 03:54 PM   #1
Rewards Points: 1,414
Running pipes through floor/ceiling
When running pipes through a floor or ceiling, what steps should be taken to ensure reasonable fire protection?
Tom738 is offline   Reply With Quote
Old 06-02-2016, 06:48 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 162
Re: Running pipes through floor/ceiling
You can fire caulk if needed- usually to the garage. Other wise, it is usually not required for home construction.
But if required, you first need to know what rating you are trying to achieve. Then you pick the method based on that. Such as 30 minute, 1hr. or 2hr.
The Following User Says Thank You to TheEplumber For This Useful Post:
Tom738 (06-02-2016)
Noisy water running pipes inside HVAC central air system in my condo unit ChicityChicity HVAC 4 09-24-2014 03:58 PM
Covering up some electrical pipes running along a wall... SpaceCoast Building & Construction 1 02-04-2014 03:09 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
running pipes in outside wall (Basement) BlueBSH Plumbing 1 10-18-2010 10:30 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
