Running New Kitchen Drain Because 1953 Wasn't Friendly With Connection Height - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 01-31-2017, 10:32 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 258
Re: Running new kitchen drain because 1953 wasn't friendly with connection height
You got a project there for sure. I still say your best option from a plumbers view is to lower the tee and repipe the kitchen line. This would keep your kitchen vent and fix the leak. But I understand where your at. My wife has asthma and sometimes I overwhelm her with demo dust with my projects...
Second option IMO is to go with the AAV. But I'd keep the kitchen line and vent in place and cap the sink branch at the existing tee only. If the shower is 2" tie the new sink line into that. 2" is large enough for a sink and shower. It's already plastic and will make the tie in easier
Old 02-03-2017, 11:57 AM   #17
Rewards Points: 22
Didn't get the reply email strange. If I ran a new line I would leave the kitchen vent in place but put a rubber cap on the end that is cut under the house and then a plug in the T to keep anything from getting in/under the house from the roof vent. The kitchen vent isn't connected to anything else as the bathroom has it's own vent.
Can the AAV be placed higher then the base of the sink so if there is a backup it starts in the sink vs coming out of the AAV all over the cabinet?
Where would be the best place to adapt to the 1 1/2 from the 2" in the cabinet space under the sink or just before it enters the sub floor into the cabinet void?
I think that is really the only other questions I had. Well 2 45s or a sweeping 90 for the change the void cabinet space to under the sink?
scgt1 is offline   Reply With Quote
Condo drain in upper unit caused drain in lower unit to leak? dangre Plumbing 15 07-09-2016 08:45 AM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
Separating Adjoining Kitchen Drain Lines MrBill_DIY Plumbing 5 01-22-2013 07:49 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
