Running New Gas Line Cost - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2016, 07:06 PM   #1
Rewards Points: 379
Running new gas line cost
I'm researching switching my electric stove to gas.
Whats a ballpark $ on having a gas line and hookup installed if im running line approximately 15 feet (to basement) or 30 feet (to feed outside house)?
Also, is this a job a competent family handyman can do?
Zamboknee is offline   Reply With Quote
Old 04-15-2016, 08:15 PM   #2
Rewards Points: 3,216
Re: Running new gas line cost
Always hard to get a quotes on a forum. Best to call a couple reputable companies in your area. Around here, certified gas fitters/master plumbers get 150 dollars an hour for labor plus materials. They will not use any parts/materials bought or supplied by homeowners. Your area may be totally different.
If you do diy, follow your local gas piping guidelines for homeowners in Iowa. (see link below). You may also have to rent tools and find a place that cuts and threads pipe. Pros have all the necessary tools and skills to do the job.
http://www.cityofdubuque.org/Documen.../Home/View/329
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
hvac benny (04-15-2016)
Running outdoor gas line SanDiego808 Plumbing 20 06-11-2017 02:03 PM
Running water line to dishwasher jkk Plumbing 6 11-30-2012 12:18 PM
cost - leak on main water line and changing valve sandrashand Plumbing 13 01-15-2011 07:56 AM
Toilet Waste Line Running Sideways ... njchan Plumbing 12 10-22-2009 05:21 PM
Running a secondary high pressure line Randell Tarin General DIY Discussions 6 02-18-2008 11:39 AM
