Running Hot Water Causes Crackling Noise In Walls - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2015, 02:24 AM   #1
Rewards Points: 42
Running hot water causes crackling noise in walls
Just moved into a used house with pvc plumping. When I run the hot water in the master sink, the wall behind the sink makes crackling noises, like the wall is expanding due to the heat. When I turn off the water, it continues to makes noises for a few minutes while it cools.
My wife says the house is haunted?!!
Is there a potential plumbing issue in the wall? The pipes come in through the crawl space.
Any suggestions?
Tia,
- Patrick
dreiding is offline   Reply With Quote
Old 01-03-2015, 03:42 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,293
The noise is just your pipes expanding and contracting from the hot water, ours does the same thing and has for many years.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
ben's plumbing (01-03-2015)
Old 01-03-2015, 06:30 AM   #3
Rewards Points: 582
yep expanding and contracting..pipes my be straped to tight ...or holes around pipe could have beed a little tight.... not to worry...
My hot water recirculation system is a disaster Michael Neill Plumbing 29 08-30-2019 06:15 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Water meter on neighbor's property / hearing water running ionbasa Plumbing 7 08-27-2012 11:45 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
