Running Galvanized Pipe Along Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2015, 02:17 PM   #1
Rewards Points: 299
Running galvanized pipe along wall
I have a need to run about 40' of 1" galvanized pipe attached to an outside wall, with two elbows in the run to accomodate a crawl space vent that is in the way. This may seem like a very stupid question, and in fact maybe I'm missing something, but it seems like once I start attaching pipe to the wall, I will have no way to get a wrench in there to tighten the fittings. I've done plenty of surface mounted work with EMT, which uses slip-in compression fittings, but not with rigid pipe that I have the crank the hell out of. Maybe if I leave the straps a little loose, the pipe will have enough play in it to pull it out far enough at the end to get a wrench on it? I know it can be done, because I've seen it done on plenty of buildings, but I just can't seem to wrap my mind around how; is there some kind of trick to it?
I can't use any other type of material because this is for gas, and galvanized steel is required outdoors.
Syberia is offline   Reply With Quote
Old 12-30-2015, 02:49 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,580
Leave the mounting straps off or loose near the end so you can flex the pipe for tightening.
Old 12-30-2015, 02:50 PM   #3
Rewards Points: 299
Ok, thanks. Knew I was probably overthinking it.
Double wall gas vent pipe? Cubey HVAC 19 10-22-2011 11:28 PM
Pipe knocking/rattle in wall profenx Plumbing 6 10-06-2011 09:01 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Galvanized pipe threads ae now smooth in one spot DJDD Plumbing 1 01-21-2010 05:58 AM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 03:18 PM
