Running Black Pipe Or Galvanized Flush To Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2015, 03:04 PM   #1
Rewards Points: 327
Running black pipe or galvanized flush to wall
I've seen some vids on youtube of some gas pipe installs, in which the black pipe is running flush to a wall, either horizontally or vertically, all around a room. It looks very neat, but it's never explained how they do it. Because the pipe is so rigid, I don't see how you could fit a pipe wrench around the fittings and turn them tightly, when they are right up against the wall.
I'd guess you could "muscle" the pipe out of line enough to turn a fitting, but that would seem like it would risk damaging the threaded joints already made.
Am I overlooking something?
Thanks.
dave11 is offline   Reply With Quote
Old 10-30-2015, 04:09 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,218
Ayuh,.... My guess is, most of it is pre-assembled, 'n then hung on the wall,.....
Old 10-30-2015, 04:22 PM   #3
Rewards Points: 327
But then it has to be attached at one end, to the incoming pipe/fitting supplying the gas/liquid, etc. That would require turning the entire assembly as one piece. But tightening just the first pipe/fitting of what you made on the ground would loosen it from the assembly.
Old 10-30-2015, 04:31 PM   #4
Bondo's Avatar
Ayuh,.... There's Gotta be unions in it somewhere,...
Old 10-30-2015, 04:52 PM   #5
Rewards Points: 76
Either unions like mentioned or they put a few parts together and then secure it to the wall. Put a section of pipe together and then whatever fittings and then loosely secure to wall and keep going and then go back and tighten everything to the wall.
ponch37300 is offline   Reply With Quote
Old 10-30-2015, 04:59 PM   #6
Rewards Points: 327
Here are two vids to show what I mean. There are no unions used.
Old 10-30-2015, 05:38 PM   #7
Rewards Points: 76
You put it together as you go but don't support it tight to the wall until you are done.
Old 10-30-2015, 05:44 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 248
That's about it- takes practice and a couple other trade secrets
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (10-30-2015), Ghostmaker (10-30-2015), ponch37300 (10-30-2015)
Old 10-30-2015, 05:49 PM   #9
Rewards Points: 582
and those trade secrets must be taken to our grave
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (10-30-2015)
Old 10-30-2015, 05:50 PM   #10
Rewards Points: 1,928
Sorry but plumbers are not made in a single year. It takes many years to even get to take a test.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (10-30-2015), TheEplumber (10-30-2015)
Old 10-31-2015, 10:57 AM   #11
All that nice pipe work and the low voltage run in crappy smurf tube
Living the dream one nightmare at a time
cad99 is offline   Reply With Quote
Old 11-01-2015, 07:37 AM   #12
Rewards Points: 327
OK. Thanks everyone.
Old 11-02-2015, 02:28 PM   #13
Rewards Points: 777
Its not flush if it has fittings like it does they will hold the pipe out far enough to tighten. Those gas lines are very low pressure, a large wrench is not required to tighten.
ct18 is offline   Reply With Quote
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 02:15 AM
Running water sound in the wall? cpourfarid New Member Introductions 2 09-26-2010 09:13 PM
Galvanized pipe threads ae now smooth in one spot DJDD Plumbing 1 01-21-2010 05:58 AM
Splicing ABS Black Vent Pipe Garfield Plumbing 1 12-07-2009 02:53 PM
