Rough In Pics. Comments Needed - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2015, 04:29 PM   #1
Rewards Points: 54
Rough in Pics. Comments needed
Hello everyone im adding a new shower to existing half bath.
i did a rough in for shower drain. 2in going across is for vent.
let me know what you think about this installation so far.
BNR34RB26DETT is offline   Reply With Quote
Old 03-16-2015, 05:13 PM   #2
Rewards Points: 1,938
Illegal dry flat vent on shower.
A vent cannot go horizontal until it is 6 inches above the fixture it is serving.
You need to figure out a way to add your sink.
The Following User Says Thank You to Ghostmaker For This Useful Post:
BNR34RB26DETT (03-16-2015)
Old 03-16-2015, 06:11 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Put a lav on that stack and you're good to go.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Old 03-16-2015, 06:12 PM   #4
Rewards Points: 54
thanks for the quick reply.
if its wet vent this is ok?
Old 03-16-2015, 07:04 PM   #5
Master Plumber
Javiles's Avatar
Wet vents Ok IPC
Old 03-16-2015, 07:14 PM   #6
Rewards Points: 582
michigan use ipc ...wet venting can be used in both vertical and horizontal applications
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 03-16-2015, 07:21 PM   #7
Rewards Points: 777
That pipe going into the wye with the vent looks mis aligned.
ct18 is offline   Reply With Quote
Old 03-16-2015, 07:23 PM   #8
Rewards Points: 582
hope that is all dry fitted...no primer....
Old 03-16-2015, 08:20 PM   #9
Rewards Points: 54
yes its all dry. just a rough in
is the 90 degree horizontal long sweet towards toilet ok? i was told to stay away from 90s in plumbing...
Old 03-16-2015, 08:23 PM   #10
From looking at the photo I'm wondering in what direction your mounting the toilet.
A toilet ruff in off the wall behind it should be 12 inches or a little more.
A toilet ruff in off the side wall should be 15 inches or better for room to wipe.
If you install a lav with a vent to air on the 2 inch it sort of looks like you will be crowding the shower. What type of base and size are you installing for the shower?
So basically A toilet needs 30 inches of space from right to left open as a minimum.
A lavatory sink depending on type can take up what ever but needs 24 inches in front of it free.
And your shower will depend on its size. Its very important you lay the bathroom out prior to gluing in the pipe and covering. I would suggest drawing what you intend to do for fixtures then we can talk about what you need for piping.
So figure out what size bathroom you intend to do. Place toilet lav and sink in that drawing so everything is easily usable.
Old 03-16-2015, 08:31 PM   #11
Rewards Points: 54
thanks for the comments.
i will be building a all tile stand up shower. 4x3 ft
toilet should be ok. 12inches and wall is still yet to be built but ill make sure to have 15 in min from the wall on the side.
one concern i have is with LAV horizontal wet vent, wouldn't i have to have the horizontal piece above 39 inch in height from floor?
Old 03-16-2015, 10:37 PM   #12
Master Plumber
Javiles's Avatar
After looking at your floor plan the plumbing layout may need to be reconfigured.
Old 03-16-2015, 10:55 PM   #13
Rewards Points: 54
What do you recommend I change with the layout?
Old 03-17-2015, 02:42 PM   #14
Rewards Points: 54
How does this look instead?
Old 03-17-2015, 05:55 PM   #15
Nope
From toilet
Toilet long sweep 90 3 in wye, 3 by 2 bushing in end of wye. 3 inch to existing just turn down with 90.
Moving to shower 2 inch 45, 2 inch wye, Off end of wye continue to shower with 2 inch trap.
Off branch of wye go back to lav wall in 2 inch turn up with 2 inch 90, 19 inches off floor to center install 2 by 2 by 1.5 inch tee. Continue 2 inch up 42 inches go horizontal tie into existing vent. That means no bath no drainage down that pipe if there is a floor above draining down that pipe it's not a vent pipe we will need to reconfigure this thing.
With 1.5 inch pick up 1.5 inch trap for lav.
BNR34RB26DETT (03-17-2015)
Basement Bathroom Rough In LarryM Plumbing 5 12-05-2014 03:45 PM
Rough Ins Needed for three piece with bath/shower? zilbeer Plumbing 3 02-16-2014 12:59 AM
Exterior double hung door - Rough Opening Measurement Help needed husbandry Windows and Doors 3 10-08-2012 02:51 PM
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 07:45 PM
