Roof Vent Or AAV For Garage? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2016, 10:08 AM   #1
hohadcr's Avatar
Rewards Points: 454
Roof Vent or AAV for Garage?
I have a detached garage about 25X20.
Right now, there is one floor drain going directly to the main sewer.
I want to add a toilet and a sink to the drain system.
Can I just put a AAV behind the sink or should I have a vent out in the roof?
The toilet can be 15-20feet away from the floor drain.
hohadcr is offline   Reply With Quote
Old 10-07-2016, 10:47 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 810
Re: Roof Vent or AAV for Garage?
You need a roof vent for a toilet.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following 3 Users Say Thank You to rjniles For This Useful Post:
Ghostmaker (10-07-2016), joecaption (10-07-2016), TheEplumber (10-07-2016)
Old 10-07-2016, 11:41 AM   #3
47_47's Avatar
Rewards Points: 320
Can you tie a toilet into your floor drain?
47_47 is offline   Reply With Quote
Old 10-08-2016, 05:22 PM   #4
Rewards Points: 1,866
Only if your good for a single flush...
Old 10-09-2016, 02:39 PM   #5
hkstroud's Avatar
Rewards Points: 6,684
Are you sure that the clean out goes to the sanitary sewer? I would expect it to drain to daylight some where. I doubt that the county or city would allow a garage floor drain to go to sanitary system. They certainly don't want you oil and grease in their system. Some places don't even allow house or basement floor drains to sanitary.
hkstroud is offline   Reply With Quote
Old 10-09-2016, 07:39 PM   #6
He said it was tied to the main sewer some areas prefer that.
Whether Or Not To Vent Roof Crazyjake8493 Insulation 12 10-26-2014 01:10 PM
snow country ridge vent on 2:12 pitch roof fxtm Roofing/Siding 4 11-01-2011 06:26 PM
very difficult house to vent roof help please marlowe Roofing/Siding 7 09-10-2011 11:57 AM
Removing Plumbing Vent from Roof WaldenL Roofing/Siding 5 08-24-2009 02:30 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
