Rinnai (R94LS) Heating Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2016, 05:12 PM   #1
Rewards Points: 4
Question
Rinnai (R94LS) I have two faucets that are separate handles for hot and cold. Both of those draw hot water. But in the last two months my shower and kitchen sink faucet (which are single handle faucet mixer values do not draw hot water all the time. However, if I start the hot water off the hot water with separate handle it works. This unit has been great since the date we bought it up until the last couple of months. The unit is clean and free of dust and build up. Also when I flip the switch to open the relief valve it starts heating the water. Heads up I have no codes and have checked. Any ideas? Thanks.
sbond007 is offline   Reply With Quote
Old 08-28-2016, 07:24 PM   #2
Rewards Points: 3,204
Re: Rinnai (R94LS) Heating Issue
Welcome to the forum 007.
With no code errors, sounds like your rinnai is working fine. It's possible the problem may be in your kitchen or shower mixing valves/cartridge. Just an idea.
jmon is offline   Reply With Quote
Old 08-29-2016, 08:43 AM   #3
Rewards Points: 4
Thanks, I figured out that my screens were clogged, which in turn slowed the water draw down. Which in turn keeps the heater from kicking on.
The Following User Says Thank You to sbond007 For This Useful Post:
jmon (08-29-2016)
Old 08-29-2016, 11:17 AM   #4
Glad you got it figured out 007. Thanks for the update.
Tags
heating issues , rinnai , tankless water heater
Strange Issue with my heating ddawg16 HVAC 0 11-07-2012 09:51 AM
Heating porch/dinning room issue vikram.bartakke Building & Construction 7 05-27-2010 01:17 PM
Drainage issue from heating system and washing machine susandlynn Plumbing 1 11-17-2007 02:28 PM
Heating Issue! not mechanically inclined HVAC 3 11-09-2007 09:40 AM
