Rigid Copper For Burial - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 2 Post By joed
  • 1 Post By joecaption
Old 02-17-2017, 10:56 AM   #1
Rewards Points: 28
Rigid Copper for Burial
Can I bury Type L rigid copper and not worry about it? Not under slab or structure. No loads on it.
No freezing here, soils are neutral.
This is to replace the 2 inch PVC water supply line that comes out of my meter at the street. Pressure coming out is 160-220 PSI, and I'm tired of repairing joints along the 190 foot route into the house every few years.
In the last 16 years, I've repaired about 8 joints, even ones that I thought I did perfectly.
I want to go copper out of the meter and up the short slope, then install a reducing valve (regulator) to step the pressure down and connect back to the 2 inch PVC.
Thanks!
3DDick is offline   Reply With Quote
Old 02-17-2017, 11:35 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,550
Re: Rigid Copper for Burial
I would run polyb in one continuous piece with no joints.
Bondo and joecaption like this.
Old 02-17-2017, 01:44 PM   #3
Rewards Points: 1,464
Considering the pressure 3/4 inch K copper would be a safe bet.
Old 02-17-2017, 03:26 PM   #4
Rewards Points: 28
Agreed, but it was hard to find. Not stocked at HD, Lowes and such.
Found some about 30 miles up the road.
Thanks!
Old 02-17-2017, 04:26 PM   #5
Rewards Points: 18,118
Why copper!
That would have to be about 4 times if not far more than the cost and nothing to gain by using copper.
Bondo likes this.
Old 02-17-2017, 05:04 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,794
Ayuh,.... I'd run the plain ole black poly pipe, or Pex, over copper everyday of the week,....
Old 02-17-2017, 05:04 PM   #7
Rewards Points: 2,630
I suspect there is a reason the PRV can't be first out of the meter but I don't know why.
Old 02-17-2017, 06:20 PM   #8
Super Moderator
joed's Avatar
Black polyethylene pipe is available in 200 psi version.
Old 02-19-2017, 05:23 PM   #9
Rewards Points: 28
Thanks for your replies. Right or wrong, smart or not, I went with Type K copper.
I this were new, I would consider poly, but to retrofit, I'd be digging up 200 feet of trench and 40 feet uphill. Not happening.
Old 02-20-2017, 08:27 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
Braze the joints. On k copper with that much pressure you'll have to, you'll need an experienced plumber, too much heat or not enough and you'll have problems
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-20-2017, 11:02 PM   #11
Rewards Points: 28
Too late. We'll see how long the soldered joints hold up.
Bad solder joints, fixable? ponch37300 Plumbing 10 11-18-2015 05:36 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Use of 3/8 inch rigid copper pipe Perry401 Plumbing 5 01-23-2012 09:38 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
