Is This The Right Tee To Use For My Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By costgeek
Old 05-30-2016, 09:26 PM   #1
Rewards Points: 374
Is this the right tee to use for my vent?
I have a dry vent that is going to be connected after my shower. The remaining bathroom fixtures are downstream so this intersection is the beginning of a wet vent. The vanity also has a dry vent that connects between the two sinks.
The old plumbing (before I tore it out) used a sanitary tee on its back for this purpose. Since I was informed (on this forum) that sanitary tees should only be used in the vertical position, I wondered if my old plumbing was done incorrectly. So I read a bunch of forums and found this subject is hotly debated.
Anyhoo, I prefer to play it safe and not use a sanitary tee on its back...so is the one pictured below appropriate for this purpose (horizontal drain pipe with a vertical dry vent)?
costgeek is offline   Reply With Quote
Old 05-30-2016, 09:42 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 180
Re: Is this the right tee to use for my vent?
If it is used for venting, above the flood rim of the fixtures served, you can use a San tee upside down, right side up, or bullheaded. Makes no difference.
The tee you show is for pressure piping
Old 05-30-2016, 09:44 PM   #3
Rewards Points: 374
This tee won't be above the flood rim. What should I use? I don't think I have room for a combination wye.
Old 05-30-2016, 10:08 PM   #4
Plumber
Rewards Points: 180
You must be 6" above the flood rim to join 2 vents together....
Old 05-30-2016, 10:12 PM   #5
Rewards Points: 374
This isn't two vents. It is one vent connecting to a waste line after the shower, but before the tub.
Old 05-30-2016, 10:12 PM   #6
Plumber
Rewards Points: 180
I just read what you have in parenthesis in your first post .
A vent rising from a horizontal drain is done using a combo only. No tees there because it is in a horizontal drain
The Following User Says Thank You to TheEplumber For This Useful Post:
carpdad (05-31-2016)
Old 05-30-2016, 10:17 PM   #7
Rewards Points: 374
I was afraid you were going to say that.
Old 05-31-2016, 07:25 AM   #8
Rewards Points: 1,302
Eplumber, when you say "combo", do you mean a wye and 45 deg street? And that combination is for better washing the pipe inside or less chance of clog? Thanks.
Also is there a book that illustrates and explains the practice whys? Most shelf books shows how but not why. The code books are worse. Example, I read 2-3 by Dan Holohan who explains why, just because his narrations were interesting.
carpdad is offline   Reply With Quote
Old 05-31-2016, 04:52 PM   #9
Rewards Points: 1,862
That Tee is a pressure pipe tee. Purchase a DWV tee.
If your under IPC Code and the tee is downstream from the shower and upstream of the tub you are installing a circuit vent.
Virginia is an IPC state so a combo wye 45 is not required as long as the vent going up is dry and vertical.
Eplumber is used to UPC the west coast code. They have weird water and it doesn't act like our east coast water.
The Following User Says Thank You to Ghostmaker For This Useful Post:
TheEplumber (05-31-2016)
Old 05-31-2016, 08:54 PM   #10
Plumber
Rewards Points: 180
We actually do use tees on their back in rare instances- but it is at the inspectors discretion. Most here view it as a tee on it's back in a drain line and not acceptable......
Been a while since you've seen clean, pure water huh?
Old 05-31-2016, 08:55 PM   #11
Rewards Points: 374
Well that's a relief. This connection is in a very tight spot....
Thanks!
TheEplumber likes this.
Tags
sanitary tee , tee , vent
Gas water heater vent too short? Ginny28 HVAC 6 05-04-2016 09:00 AM
Plumbing Book Reccomendations patrickpresti Plumbing 173 02-04-2016 06:15 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
