Richmond Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2015, 09:06 AM   #1
Rewards Points: 2
Hello..I have a Richmond Hot Water Heater Model# 6E550-2. Earlier this week I had to shut the main water off to my home to replace a PVC pipe that snapped into. When I cut the main water supply back on I checked for any leaks, etc..cut my tank back on, now I have no hot water pressure !! It's been 3 days now and I still don't have any pressure. I have washed several loads of clothes..washed dishes, etc...what can I do? One plumber told me to give it time for the pressure to build back up..what pressure..my cold water has lots of pressure.. If someone can please tell me what to do..I will really appreciate any advise..
DebClark/SC
DebClark is offline   Reply With Quote
Old 12-12-2015, 06:55 AM   #2
An old Tradesmen
Rewards Points: 9,238
Moved to Plumbing forum.
Old 12-12-2015, 08:53 AM   #3
Rewards Points: 3,220
DebClark/SC
The valve you used to turn it back on, was it an old gate valve (wheel type handle) or is it a ball valve (lever type handle). Post a picture of your wh set-up. Thanks.
Sometimes those old gate valve types get stuck. You think it's all the way open, but it's really not.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Ghostmaker (12-12-2015)
Old 12-12-2015, 11:51 AM   #4
Rewards Points: 3,286
Your water heater might have heat traps in the inlet and outlet up top (they look like ordinary nipples).
These can clog with sediment notably after you do some work on the plumbing system.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
Ghostmaker (12-12-2015), throrope (12-13-2015)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
