Rheem Tank Pilot Not Staying Lit? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2016, 06:48 PM   #1
Rewards Points: 2
Rheem tank pilot not staying lit?
My dad had a new Rheem hot water tank installed for floor heating. The weather now is cool and rainy. He lit the tank and a short time later it went out. He kept relighting it until it stayed lit after 20 mins. A plumber saw a drip when examining it when it was cool. He thinks the humidity in the flue is dripping down and putting out the burner until it is heated enough to displace the humidity in the flue. Has anyone had this problem?
gerryco is offline   Reply With Quote
Old 07-12-2016, 08:21 PM   #2
Rewards Points: 3,202
Re: Rheem tank pilot not staying lit?
Welcome to the forum gerryco.
If it's brand new and just installed, call back installer/manufacturer and let them know of the situation. Should be some kind of installer or manufacturer warranty.
If you installed it, recheck your work and make sure everything is installed to manufactures specs as stated in owners manual, especially venting. If it's not venting properly, getting the appropriate amount of air, or bad thermocouple the pilot will not stay lit. Just a suggestion.
jmon is online now   Reply With Quote
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Gas (propane) Fireplace: Pilot OK, full flame goes out darthsmozers HVAC 4 11-23-2013 02:32 PM
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
