Reusable Toilet Ring ? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Old 09-29-2017, 07:51 AM   #1
Rewards Points: 1,256
reusable toilet ring ?
the rubber boot type that glue to the bottom of the toilet.
are these any good ? any issues/precautions ?
i am going to reset my toilet in a new flange, and i may need to remove it in the future (possible flooring change or whatever).
i just hate dealing with the wax.
i did search, but threads where kinda old.
thanx
Fix'n it is offline   Reply With Quote
Old 09-29-2017, 10:08 AM   #2
Rewards Points: 1,116
Re: reusable toilet ring ?
Most are squashed/ruined/full of bad stuff etc. Wear disposable gloves. To reshape old one is more work than removing it. If adding tile or thicker tile when doing new floor, get a thicker ring. Kind with plastic (rubber boot type) bottom that inserts into drainpipe works well.
diyorpay is offline   Reply With Quote
Old 09-29-2017, 01:41 PM   #3
Oso954's Avatar
Rewards Points: 1,890
I've used the Fenco waxless a couple of times.
I like them, have not had any problems with them.
The key is cleaning and drying the area around the horn before the install, so the adehesive takes very good hold.
Oso954 is offline   Reply With Quote
Old 09-29-2017, 02:14 PM   #4
Rewards Points: 1,066
I haven't used the retrofit ones, but I did put in a Toto in my house that uses the rubber boot. Since it was our only toilet in the house it was really nice to be able to quickly reinstall the toilet when needed and then pull it again to keep working there.
It's been in for years and no problems so far with it, knock on wood!
NotyeruncleBob is offline   Reply With Quote
Old 09-29-2017, 02:24 PM   #5
Rewards Points: 898
You talking about this?
https://www.menards.com/main/plumbin...8652074&ipos=2
BIG Johnson is offline   Reply With Quote
Old 09-29-2017, 03:23 PM   #6
Rewards Points: 114
A wax ring is under a dollar and works fine. Why bother with somthing else?
2x_Tom is offline   Reply With Quote
Old 09-29-2017, 04:31 PM   #7
Naildriver
chandler48's Avatar
Rewards Points: 3,674
under a dollar
Not quite. Try $6. The waxless rings are competitive in price, however.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-29-2017, 05:23 PM   #8
Rewards Points: 1,950
Make sure that the bottom of your old toilet is squeaky clean so the adhesive will adhere.
Old 09-29-2017, 08:41 PM   #9
Rewards Points: 114
Originally Posted by chandler48 View Post
under a dollar
Wrong. $0.96.
No idea where you're getting ripped off.
Old 09-30-2017, 08:24 AM   #10
Originally Posted by BIG Johnson View Post
thats the one. doesn't have that much glue on it thought . but it is really sticky stuff.
yeah, i cleaned it super good.
and, i plan to put some kind of lube on the male part and inside the flange.
so, in theory, it would come out easier. soap, white grease, Vaseline, ???
Old 09-30-2017, 08:29 AM   #11
Naildriver
chandler48's Avatar
Wrong. $0.96.
I posted a link. You didn't.
Larry......
Old 09-30-2017, 09:48 AM   #12
Lawrosa's Avatar
Rewards Points: 100
That glue one dont work too good. If your going to use another product other then wax use a sani seal..
These are the best in terms of leak free like wax...
http://www.homedepot.com/p/Toilet-Ga...BL01/203564758
Wax seals are 1.50$. This is what I use. I dont use the wax seals with the plastic funnel built into it..Those are about 4 bucks..
http://www.homedepot.com/p/Everbilt-...7510/203763996
http://www.homedepot.com/p/Everbilt-...7513/203763999
Lawrosa is offline   Reply With Quote
Old 09-30-2017, 05:04 PM   #13
I used soapy water on the outside of the rubber seal. I removed my toilet around 5 times while doing tile work and reset the toilet. Still using it to this day. 7 years or so.
Yodaman likes this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Fix'n it (10-01-2017)
Old 10-01-2017, 06:45 AM   #14
did you see the reveiws of those, pretty crappy.
Old 10-01-2017, 07:57 AM   #15
Big Dog
Drachenfire's Avatar
Rewards Points: 4,910
I use Sani-seal rings. They are easier to install, reusable and seals well.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Help with stink coming from Toilet area. Integraoligist General DIY Discussions 9 11-16-2011 05:16 PM
Wax Ring Replacment and Toilet Leak kennykenny Plumbing 4 11-27-2010 02:43 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
