Returning After A Long Absence - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2017, 12:24 PM   #1
Rewards Points: 4
Returning after a long absence
I've been away from home for a few months and had shut off my water main. Should I empy my water softner and drain the hot water heater to make sure I'm getting clean water?
Thedude2741 is offline   Reply With Quote
Old 04-19-2017, 01:24 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,514
Re: Returning after a long absence
You on well or city? Shouldn't be "unclean" if you are on city but it can't hurt to at least run the furthest outlet for a while and then flush out all the lines individually by turning out the outlets.
Old 04-19-2017, 01:46 PM   #3
Rewards Points: 4
I'm in the city. Just wanted to be sure the water would be sanitary after sitting so long. I was ? my if rechargingvthe water softener and flushing the hot water heater but didn't know if it was necessary
Old 04-19-2017, 05:06 PM   #4
Rewards Points: 18,990
Should be a total non issue.
Big difference from a few months and a few years.
Water heaters should have a few gal. drained out of the bottom anyways to drain out the sediments in the bottom at least every 6 months for a longer life.
Old 04-19-2017, 05:19 PM   #5
Rewards Points: 6,566
I would flush the lines to admit fresh treated water to those and the water heater. .
https://www.cdc.gov/healthywater/dri...infection.html
Old 04-19-2017, 06:22 PM   #6
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Send the softener through a regen and then after it has been done then do the flush as SeniorSitizen has laid out.
Akpsdvan is offline   Reply With Quote
Another time-lapse! This one twice as long! katanna General DIY Discussions 0 11-03-2015 03:44 PM
Dryer vent - How long is too long? J S Machine Appliances 11 07-26-2015 07:25 AM
How long between tiling steps? ptraz Flooring 4 03-12-2010 07:13 PM
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 08:10 AM
The long, dark road of renovation. Curb Feeler New Member Introductions 1 02-03-2009 01:47 PM
