Retaining Lever Control Of Pop-Up Drain (Non-Overflow Sink) - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2016, 04:46 PM   #1
Rewards Points: 100
I am purchasing an oval copper undermount sink and a Delta single hole faucet. The sink has no overflow provision. Of course the included Delta drain/pop-up assembly is for an overflow sink. I want to retain the faucet's lift-lever control for a drain stopper. Between Delta, the sink manufacturer and a big box store tech line, everybody says the only thing available is a drain assembly that either has no stopper provision, or is the push to engage, push to release variety. I say B.S.! Putting your hands to the bottom of a (potentially well soiled) pool of water after washing face/hands etc. to drain the sink makes no sense. This is a significant upgrade from "builder quality" materials. It's ludicrous to sacrifice mechanical control and revert to the kind of drain that is suited for college dorm. I cannot be the first person to face this situation and not be satisfied with those limitations. Any suggestions? Thanks.
zippinbye is offline   Reply With Quote
Old 02-13-2016, 05:24 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
whats the difference if there is or is not an overflow hole? just dont overflow the sink when filling it...just install the faucet and pop up...
WhatRnsdownhill is offline   Reply With Quote
Old 02-13-2016, 05:56 PM   #3
Rewards Points: 100
That is not the issue. I went through the same logic process you are putting forth. Simple rule, don't walk away from a filling sink. Works in my kitchen, should work in the bathroom. But that's not the concern.
My query is specific to the primary drain and stopper operation. You will recall a "normal" drain assembly has the side-located ports that extract the overflow water, through the hollow cavity in your typical overflow-equipped sink. Once installed in an overflow sink, those ports are not visible from above or below, they are internalized in the sink. Place the same drain in a single-layer sink drain hole, and those drain ports are now in your vanity cabinet below the sink structure - obviously allowing water to vent sideways to some extent. Not workable.
I'll probably end up manufacturing my own from hybrid parts if necessary, or determining a way to block-off the overflow ports on the Delta drain assembly ... fiberglass layup wrapped around the holes perhaps? But I really should not have to do that. These copper sinks are increasing in popularity and I'm no pioneer in facing the issue.
Old 02-13-2016, 06:05 PM   #4
Rewards Points: 582
the pop-ups supplied in most vanity faucets ..are for standard sinks with overflows...hence standard...what you seek is a special order pop up assy for thin sinks without overflows...check with you supplier...
Old 02-13-2016, 06:05 PM   #5
gotcha, you didnt explain that as well in the first post...depending on the pop up you bought, many come 2 piece, the top piece with what you descripe for the overflow and the bottom piece that has the rod for the pop up....you can get just the top piece for that type of sink and if you get the same threads as the bottom of the pop up it should screw on and your set, just make sure the sealing pop up fits the new top piece, it may be a bit of a job to match all that up, but doable...have you tried some of the restoration sites that sell new old looking sinks, for a pop up drain for that sink?
Old 02-13-2016, 06:09 PM   #6
Rewards Points: 582
maybe something like this
Old 02-13-2016, 06:12 PM   #7
how thin is the sink at the bottom where the drain goes?
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
sink drain exterior wall iskyfly Plumbing 11 02-04-2012 06:38 PM
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 11:49 AM
overflow drain in non overflow sink? forresth Plumbing 1 10-06-2010 06:09 AM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 05:36 PM
