Resolder Mixing Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2015, 06:24 PM   #1
Apparently the plumber who did the plumbing in my fathers rental didn't solder in the mixing valve properly. When the diverted valve is activated the mixing valve is trickling water from the pipe that supplies the valve at the bottom. It is in a very tight space, I have a feeling I am going to have to cut a square access hole in the wall. Will I be safe removing the cartridge and then de soldering the joint in question, cleaning the joints, prepping them and resoldering?
Mml665 is offline   Reply With Quote
Old 12-31-2015, 07:28 PM   #2
Rewards Points: 582
Iam guessing your talking about the tub filler spout...it all depends where its leaking at..if it on the diverter yes remove cartridge ...if its on the piping going to spout you don't have to remove cartridge...check to make sure its not leaking at filler connection ...pictures would help...
Old 12-31-2015, 08:05 PM   #3
It is leaking from the mixing valve that controls the hot cold. The leak is where the pipe is going into the bottom of the control valve
Old 12-31-2015, 08:31 PM   #4
Rewards Points: 582
then yes I would remover the cartridge before you repair because it very easy to over heat them while trying to repair a leak....
Old 01-01-2016, 09:24 AM   #5
Thank you! I was hoping to not have to cut an access hole in the wall, but I believe I will have to.
The Following User Says Thank You to Mml665 For This Useful Post:
ben's plumbing (01-01-2016)
Old 01-04-2016, 11:08 AM   #6
Rewards Points: 767
They have access panels you can install after the repair. It will be used at some point down the line to replace that shower diverter
ct18 is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Mixing Valve replacement mediaman67 Plumbing 20 03-02-2010 10:19 PM
Mixing Valve Replacement TeamRoper Plumbing 3 02-15-2009 04:18 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
