Residential Water Pressure Changes When Home Alone - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2016, 12:53 PM   #1
From Philadelphia
Rewards Points: 291
Sometimes when taking a shower, I notice that the shower will lose a little pressure and the temperature would get a little cooler, as if somebody were to flush a toilet or turn on a cold water faucet or something. But this happens even when there is nobody else in the house, which baffles me. Also, this is city water (not well water) and this still happens when the washing machine is turned off.
What could cause this?
hellohello is offline   Reply With Quote
Old 02-17-2016, 01:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,036
Ayuh,.... It would get Hotter, not colder in that case,....
What sorta heatin' system ya got,..??
What sorta water heater ya got,..??
Old 02-17-2016, 01:59 PM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
do you have a wall hung tankless heater?
WhatRnsdownhill is offline   Reply With Quote
Old 02-17-2016, 02:28 PM   #4
From Philadelphia
Rewards Points: 291
You're right, it get's hotter, my mistake. Gas fired boiler and 40-gallon gas fired water heater.
No.
Old 02-17-2016, 02:47 PM   #5
could be a leaky toilet and when it gets low enough in the tank the fill valve opens up..
Old 02-17-2016, 02:49 PM   #6
Rewards Points: 5,538
I'll take a WAG. You have a pressure reducing valve on the municipal water line and / or a single handle shower control temperature balancing valve.
Old 02-18-2016, 07:07 AM   #7
From Philadelphia
Rewards Points: 291
Doubt it, I've never noticed the toilet running otherwise.
There IS a pressure reducing valve on the municipal water line just as it enters the house. But my understanding is that this would reduce the pressure to a constant pressure, and not fluctuate. And no to the single-handle shower control temperature balancing valve. It's two separate valves - hot and cold.
Old 02-18-2016, 07:11 AM   #8
the PRV could be telling you it needs a cleaning or rebuild, and that is why pressure if fluctuating...
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
JERRYMAC (02-19-2016)
Old 02-18-2016, 07:24 AM   #9
From Philadelphia
Rewards Points: 291
Interesting thought, I'll have to look into that.
Old 02-18-2016, 07:26 AM   #10
its a process of elimination to trouble shoot...that would be one of the first places, as you eliminated afew other problem ares by not having them..
Old 02-18-2016, 10:18 AM   #11
Rewards Points: 3,218
Agree with others, definitely check out the prv for proper operation, adjustment and cleaning. Take some pressure readings at hose bib with and without a faucet on and post results. Sometimes all they need is a little cleaning and adjustment.
There is a screen on the inlet side that can get clogged with sediment and may affect the way it works. I've seen that before. They don't last forever.
If it's old and needs to be rebuilt, better and easier to replace it, imo.
Please post a picture of the prv and water heater set-up. Thank you.
Hope you get it figured out soon.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Well Water Pressure Fluctuation cforbes Plumbing 13 10-01-2012 06:52 AM
Water Pressure in Home - Pressure Reducer or Expansion Tank georgemeaders Plumbing 6 09-12-2012 08:51 PM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
Decreased Water Pressure in home Gordon07 Plumbing 4 12-03-2009 11:05 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
