Rerouting Sump Pump Drainage - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2016, 08:53 AM   #1
Rewards Points: 2
Rerouting sump pump drainage
I'm wondering if someone could give me details on how easy or not easy it would be to reroute our sump pump drainage from the main sewer line to our yard?
mrsorr is offline   Reply With Quote
Old 06-12-2016, 10:01 AM   #2
Retired Moderator
Rewards Points: 7,174
Re: Rerouting sump pump drainage
That is not usually to difficult---in a nut shell--cut and cap the house drain and then route a 1 1/2" pipe from the pump to the outside of your house--
Many more details will be needed to give you directions:
Do you have a drywalled ceiling in the basement?
How far from the pump to your proposed exit point?
Frame construction or brick/masonry?
Once the pipe exits the house--
Is there natural pitch in the yard to carry the water away from the foundation?
Do you need to worry about freezing ?
Any finished areas like patio or side walk?
More details please.
Old 06-12-2016, 02:08 PM   #3
Rewards Points: 109
Did his for a buddy. It too long ago, we actually teed off the drain to the street now he can issue either street or yard by the turn of a valve
Olcrazy1 is offline   Reply With Quote
Help with Sump Pump Issue (Drainage as well) neverlandpirate Plumbing 2 12-30-2015 07:57 AM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
sump pump drainage ramelleday Landscaping & Lawn Care 1 09-04-2010 10:37 AM
Sump pump drainage problem sk8z Plumbing 6 11-29-2008 10:09 PM
