Rerouting PVC Pipes Through Floor Joists - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2015, 02:36 PM   #31
For what it's worth, the only time I've ever seen pvc for water lines was outdoor underground irrigation. I used to like CPVC for its quick and easy cutting and gluing, but I've found it becomes really brittle after time. Try to cut and it can shatter. I'm with Joe, pex and sharkbites are the greatest
dangdave is offline   Reply With Quote
Old 03-29-2015, 09:06 PM   #32
Rewards Points: 582
Originally Posted by TheEplumber View Post
Ben, in my area PVC is allowed for potable water outside the structure's footprint.
after some research..i found that some areas due allow pvc for main water line installs up to the house ..but not inside,....why is anybodys guess only that the code provides a list of materials used and that they rely on the manufactor of the pipe to provide its safety level for use....in my local area its not approved... so yes it may be approved in your area as e mentioned...sorry if i mislead anyone..ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (03-29-2015)
Old 03-29-2015, 09:16 PM   #33
Rewards Points: 750
a vast majority of all plumbing jobs ive seen (like 80%) have schedule 40 pvc pipe for cold water & cpvc for hot. inside & outside the home. all others are usually old school iron, copper & very rarely I will come across some pex.
I have never heard of a rule before forbidding pvc pipe. That is like all I even see sold in big box stores. sch 40 pvc & cpvc.
Hick is offline   Reply With Quote
Old 03-29-2015, 09:41 PM   #34
Rewards Points: 582
ok to clear up some confusion....in 1 st post ...thougth op was talking about regular glue up pvc.... which would be prohibited because of the solvent used.. main water line have been run in plastic like this in areas around me but not allowed in my area...ok not to make excuses but iam on mild pain killer from a root canal that i had done...boy am i going down hill can't even hold a little pain pill
Old 03-30-2015, 12:07 AM   #35
Rewards Points: 750
So...just so I am fully clear for all future plumbing I come across. This
Is NOT allowed for potable water inside buildings?
Old 03-30-2015, 03:56 AM   #36
Rewards Points: 1,414
Where I am, the hot and cold water supply lines are required to be the same material, so if you use cpvc for the hot you have to use it for the cold.
Tom738 is offline   Reply With Quote
Old 03-30-2015, 07:43 AM   #37
A "Handy Husband"
rjniles's Avatar
Rewards Points: 892
Why would PVC not be allowed because of the solvent, but CPVC be OK? They both use similar solvent cement.
In my area regular PVC is used inside and outside for cold water. Often PVC is used for cold and CPVC is used for hot. No requirement to use the same material. If you had copper existing you can repair or make additions with PEX (and is commonly done).
PEX has taken over the plumbing market in this area. I never see copper or CPVC used any more. PVC is the standard from the meter to the house. (Meters are located at the street.)
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following 3 Users Say Thank You to rjniles For This Useful Post:
ben's plumbing (03-30-2015), Hick (03-30-2015), Yodaman (03-30-2015)
Old 03-30-2015, 02:55 PM   #38
Rewards Points: 582
the main water lines in my area installed to code do not allow glued joints ...they are one continous run with compression adapters at the ends of the pipe....no fittings between curb stop and meter....Iam with the rest of you guys if pvc glue pipe can be used outside why not inside...I don't and have not used either...
Old 03-30-2015, 05:54 PM   #39
Rewards Points: 1,942
PVC is not allowed inside a house because it can not handle hot water. The burst pressure you see on the pipe is at 78 degrees or something like that. Interior water sometimes can allow hot back flow down a code line. Hence it is not approved for water distribution (interior piping).
So your choice is CPVC, Copper, Galvanized or pex.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (03-30-2015), Homerepairguy (03-30-2015)
Old 03-31-2015, 10:26 AM   #40
Rewards Points: 229
Originally Posted by Yodaman View Post
Make the switch to pex. You will be happy you did. The tool cost has come down to around $50. With pex you can have longer runs with less fittings which means less potential for a leaks. The skill level required to run pex is simpler than cutting and glueing.
Over the years when doing a large project, I would buy one new tool that I absolutely had to have!
I only need to replace the supply lines in the photos from my original post. Is it worth switching to PEX for such a short run? If the tool itself is like $50, I'm not sure I'll do it. Is it possible to connect CPVC and PEX together?
gtothek is offline   Reply With Quote
Old 03-31-2015, 11:38 AM   #41
Property Mgt/Maint
Rewards Points: 8,202
Yes you can connect your CPVC to Pex with a sharkbite (push connect) coupling. My opinion on any tool cost is once I have it I will always have it and be ready for the next job. As your skills and confidence grow the project sizes increase and so to will your tool collection. Even at one tool at time. Good luck with your project.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 03-31-2015, 11:45 AM   #42
A "Handy Husband"
rjniles's Avatar
Rewards Points: 892
There is also a fitting that cements to CPVC at 1 side and has a PEX barb on the other.
Old 03-31-2015, 11:53 AM   #43
Property Mgt/Maint
never used one but I am sure it would work fine and be less expensive than the shark bite, (unless you were buying a can of glue and primer for one or two connections)
Insulating attic pipes thew60 Insulation 4 01-10-2014 02:23 PM
rerouting water pipes, is this way ok? jsunsun Plumbing 4 05-30-2013 09:51 PM
rerouting pipes Lemkie Plumbing 4 03-08-2013 05:05 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
