Replacing Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2015, 01:26 PM   #16
Rewards Points: 38
Alright, I'm likely making this more complicated than it really needs to be.
To add the expansion tank, I need to figure out the placement and routing of the cold water so that the expansion tank is attached to a tee connector.
Because my lines are within 10" of the water heater itself, this will require me to extend the cold water across a wall and back. I'll have to secure the cold water pipe to the wall and strap the tank as well, correct?
Zen1300 is offline   Reply With Quote
Old 05-30-2015, 03:39 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 290
What I would do:
Screw a 3/4" galvanized tee on top the CW tank nipple. Put a 3/4"x 6" galv. nipple into the tee branch, which should be pointing away from the Bvent.
Screw a 90 on the nipple- looking up. Then the tank on top the 90.
The top of the tee will get a short nipple the receive your nut from a new flex line.
The galvanized fittings are rigid enough to support the tank.
material list-
1- 3/4 tee
1- 3/4 90
1-6" nipple
1- 21/2" nipple
The Following User Says Thank You to TheEplumber For This Useful Post:
tylernt (05-30-2015)
Old 05-30-2015, 07:14 PM   #18
Rewards Points: 38
Like I said, I was overcomplicating it. I hadn't realized the tank could be inverted. Based on your description, this is how I visualize it... (sorry, I'm a visual type of guy).
Old 05-30-2015, 10:04 PM   #19
Rewards Points: 7,044
Usually the only complaint about push to fit devices is that people don't trust they won't ever leak. So some people won't use them in concealed areas. Personally I trust them (I've certainly seen soldered copper joints leak as well.) But in your case it is exposed, so I see no reason you wouldn't want to use one. Super convenient and worth the couple extra bucks, unless you just happen to enjoy sweating copper and already have all the equipment and materials.
jeffnc is offline   Reply With Quote
Old 05-30-2015, 10:06 PM   #20
I believe most pressure tanks call for support. I see them unsupported all the time whe used with copper pipes. I use PEX myself, so of course I wouldn't install a tank in that manner unless it were well supported.
Old 05-30-2015, 10:46 PM   #21
Plumber
Rewards Points: 290
That is basically the what I "tried" to describe. I put the tee vertical with a 6" nipple in the horizontal- then the tank. Off the top of the tee is the flex and ball valve.
The idea is to get the tank away from the flue, yet allow the galv. pipe to support the exp. tank.
For what it's worth, you could put the tank on it's side down at the platform and pipe pex to it and it should still pass inspections. Elevation should not matter- just secure
Old 05-31-2015, 07:29 AM   #22
Rewards Points: 38
I didn't think it would support the tank horizontally when full of water.
Old 05-31-2015, 05:29 PM   #23
Rewards Points: 38
I measured the pressure at my hose for 24 hours and it peaked at 82psi.
It looks like I can put a Pressure Regulator Valve at the house shutoff valve (near the hose in front). There is a main shutoff valve with the meter at the curb, but that would be harder to get to I think.
I also have this on the grass in the front - believe it to be part of the sprinkler system, but I've not see this configuration before.
I assume that adding a PRV might change my sprinkler coverage.
I'm ready to submit my permit application and then it is time to get started. I'll post completion pics when everything is done.
Old 06-04-2015, 04:09 PM   #24
Rewards Points: 38
Alright, so adding the pressure reducer is the latest challenge.
It looks like I'll need to dig out the main next to the house (not the main with the meter at the curb).
I dug out some of the dirt just to see what I was going to have to deal with. I expected a single pipe into the house, but found that it had a smaller tee on it.
Any ideas what this is for?
It looks like what I need to do is expand this hole to reveal more of the pipe so that I can sweat a new run with a ball valve and a pressure reducing valve. Then put a larger valve box in its place to accommodate everything.
Just replacing a water heater has progressively gotten more challenging.
Old 06-04-2015, 04:30 PM   #25
Rewards Points: 3,492
Could be for anything like water heater, outside hose bib, etc. Just a guess. Have to trace out where in comes in at the house and find out what it goes to. Just a suggestion.
Others will be along with more advice/ideas.
jmon is offline   Reply With Quote
Old 06-04-2015, 04:34 PM   #26
Would it be easier to add the prv inside the house? From the pic that hole looks rather tight to work in. You may have to add a seperate 1/2 pvr to that 1/2 inch line when you find out what it goes to.
If it goes to an outside hose bib, I wouldn't worry about it. Don't know if you have a boiler, they usually have a separate prv on the incoming line set at 15psi.
You state your incoming psi is 82. I agree anything over 80 should be addressed. Hope you can add one somehow without too much work.
Please wait for the plumbers to respond, they will know for sure what to do. Thanks.
Old 06-04-2015, 07:00 PM   #27
Rewards Points: 38
Where would I put it then?
You're right. That smaller pipe must go to the hose bib right next to it. Duh.
But the main line would enter the house and split to the various faucets. I assumed the valve needed to be before entering the house. I didn't find any alternatives when I Google.
Old 06-04-2015, 07:48 PM   #28
Not necessarily. Find the point of entry where it enters the house, sometimes there is enough pipe to work with before it branches out and you can put a prv there.
Old 06-04-2015, 07:56 PM   #29
Rewards Points: 38
That pipe enters under the concrete slab at my son's bedroom. The closest faucet is the guest bathroom.
I would have to cut out drywall in my son's bedroom. I'm fine with drywall, but it seems easier to dig out around the pipe.
Old 06-04-2015, 08:10 PM   #30
I understand. Do whatever is easiest for you. Seems like you will have to make the hole a little bigger so you can get the prv on. Myself, I would prefer to deal with the drywall and put an access panel in so it's easily accessible for future repairs, adjusting water pressure, etc.
Remember, they do go bad. So make sure you get one with unions on both ends for easy swap out in the future. Something like this. Just a suggestion.
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
