Replacing A Tub With Copper Drain Piping - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2015, 07:54 PM   #1
Rewards Points: 76
Replacing a tub with copper drain piping
A friend asked me to help replace a tub in his bathroom. I've torn out cast iron tubs and replaced with a new one before but never dealt with a drain like this. Can I just cut out the drum trap and then use a proflex type coupling to adapt from the current drain line to new PVC with a new PVC P trap and new tub drain for the new tub?
ponch37300 is offline   Reply With Quote
Old 12-12-2015, 09:32 PM   #2
Rewards Points: 18,990
Remove all of it including the overflow, and the drum trap, and replace it all with PVC.
Old 12-12-2015, 09:38 PM   #3
Rewards Points: 76
That's the plan. Just wondering after I cut out the drum trap what the best way to adapt to PVC is? Just a proflex coupling?
Old 12-13-2015, 09:03 AM   #4
Rewards Points: 1,952
Yes a proflex will do the trick. On the outlet side of the drum trap is it galvanized or copper. Whatever it is buy that type pipe by plastic proflex.
Ghostmaker is online now   Reply With Quote
Fernco for sink drain to copper? killerformula Plumbing 6 10-28-2014 12:07 PM
Pex or Copper piping? for apartment or house crayola110 Plumbing 13 11-16-2013 08:18 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Replacing sink drain tube n0c7 Plumbing 7 04-16-2009 07:16 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
