Replacing A Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2015, 03:01 PM   #1
Rewards Points: 258
Replacing a toilet
Okay I am replacing a toilet in my house. I need some help figure out what off set to use. Here is a pic of from the finished dry wall to the closet flange bolt. The real hope is that the closet flange is still in good shape.
redman88 is offline   Reply With Quote
Old 05-19-2015, 03:07 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
Theoretically your offset is to center of drain.... but that looks like a standard 12 tiolet....and you can get adjustable flanges that will provide 2" of play if you have a problem.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-19-2015, 03:10 PM   #3
Rewards Points: 582
yep get a regular 12" rough toilet
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
Replacing Toilet w/ Sink? Mabrins Plumbing 4 05-20-2013 07:01 AM
Basement toilet leaking - even after replacing ring chieftaing Plumbing 7 02-20-2013 04:58 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Replacing a toilet flange jayp Plumbing 5 06-11-2008 09:43 AM
