Replacing Shut Off Valve ... Couldnít Get Main Line To Stop Dripping - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree11Likes
Old 11-28-2017, 02:10 AM   #1
Rewards Points: 960
Replacing shut off valve ... couldnít get main line to stop dripping
Iím replacing an old shutoff valve with a ball valve style shutoff.
I shut off the street main and the feed from the hot water tank.
The cold line sweat without issues. The hot kept dripping and I couldnít get the solder to melt.
I tried the bread trick - no luck.
Would running a drill pump with a hose up the line take out enough water? It doesnít help that the line Iím sweating is facing down - no where for the water to pool. Or should I have waited longer for the hot to stop dripping?
I ended up sharkbiting it. First time using a shark.
What are options here?
I could leave the sharkbite fitting in place and sweat on the rest of the line. (Iíd leave the shark in the open position after i sweat the line.). Iíve never used sharkbite before so I am a bit concerned.
jaketrades is offline   Reply With Quote
Old 11-28-2017, 02:43 AM   #2
Rewards Points: 960
I forgot to clean the flux off the copper pipe I sharkbite!!! Is that gonna be a problem?
Old 11-28-2017, 05:01 AM   #3
JUSTA MEMBER
Rewards Points: 3,942
Re: Replacing shut off valve ... couldnít get main line to stop dripping
You're hot water will drip until the tank is near empty, or at least below the level of the fitting that you are replacing.
Best to open a faucet to let it drain, or attach a hose to the tank drain and to a sewer drain.
Do you regularly drain the water heater to rid it of sediment, You should at least yearly to protect your heat elements, Deposits build up and cause them to corrode and either short out (if electric), or get hot spots and burn through ( if gas).
ED
jaketrades likes this.
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
jaketrades (11-28-2017)
Old 11-28-2017, 05:34 AM   #4
Rewards Points: 960
Ed, the tank is in the basement and the fitting is a couple flights higher.
I drained all faucets at the same level and above the fitting.
Iíll look for a drain out valve on the tank. What should I be looking for?
Thx
Old 11-28-2017, 06:01 AM   #5
JUSTA MEMBER
Depends on which tank you have, a picture would help.
Usually right on the front, a regular garden hose should fit it and the valve looks just like a regular hose bib.
You might need a new shutoff valve to the plumbing.
This is usually right near the top of the tank, to ease in replacement of the old tank when it dies.
ED
Old 11-28-2017, 06:24 AM   #6
Rewards Points: 960
Iíll take a pic later. Iím assuming the drain out valve will be near the bottom of the tank.
The shut off valve is on the top. Itís a ball valve - seems to be in decent condition, but yeah it may need to be replaced.
Old 11-28-2017, 06:35 AM   #7
custom user
Rewards Points: 1,820
Yes, the drain is on the bottom. I usually open the tub valve after shutting water off. The hot lines also have pressure but it should stop dripping. The Sharkbites work by sealing an o-ring so I'd imagine the flux would be an issue. That's some gnarly looking plumbing!
JasperST is offline   Reply With Quote
The Following User Says Thank You to JasperST For This Useful Post:
Old 11-28-2017, 08:02 AM   #8
Rewards Points: 10,824
I open all faucets to help water drain. I recall one time where I needed to wait 20-30 minutes for water to fully stop dripping.
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Old 11-28-2017, 05:36 PM   #9
Rewards Points: 960
ED
Is that the release valve?
Old 11-28-2017, 06:04 PM   #10
retired framer
Rewards Points: 15,654
Like this
The Following User Says Thank You to Nealtw For This Useful Post:
de-nagorg (11-28-2017)
Old 12-02-2017, 02:46 AM   #11
Rewards Points: 960
Got the shutoff valve sweated on. I shutoff both the hot and cold, bleed the water tank but there was still a drip in my copper line. But it seemed a little slower than before.
It sweated easily.
Thanks for all the help!!
SPS-1 and de-nagorg like this.
Old 12-02-2017, 01:52 PM   #12
Rewards Points: 1,950
Make sure you use a plastic spacer between the copper and the steel studs. If you dont they will leak if touching due to rubbing through or dissimilar metals.
The Following User Says Thank You to Ghostmaker For This Useful Post:
jaketrades (12-04-2017)
Old 12-02-2017, 01:54 PM   #13
Rewards Points: 960
Will duct tape work ?
Old 12-02-2017, 03:14 PM   #14
JUSTA MEMBER
I would just "bite the bullet" and get plastic grommets, and put in there, won't cost much, and will keep the two metals from having a difference of opinion, and eventually leaking.
Then you will need to do this all over again.
Duct tape is a temporary fix at best.
ED
Old 12-02-2017, 04:30 PM   #15
custom user
Originally Posted by Nealtw View Post
Like this
Shouldn't that heater vent be going uphill?
Valve on water line to water heater dripping a lot . . . Michaelangelo Plumbing 12 03-20-2015 06:09 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 12:29 AM
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 04:34 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
