Replacing Showerhead - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2015, 02:15 AM   #1
Rewards Points: 28
replacing showerhead
I have a Kohler shower kit with a handshower and regular showerhead. I bought a new Kohler showerhead but when I took the old one off there is an adapter on it to screw into the diverter piece. I tried to remove it to put it on the new showerhead but it won't budge. I called Kohler and they are sending me a screen washer. I didn't know that until I hung up with them. They are useless. Any suggestions? thanks.
lindapalmbay is offline   Reply With Quote
Old 01-23-2015, 05:51 AM   #2
Retired Moderator
Rewards Points: 7,174
A picture would help----
jmon (01-23-2015)
Old 01-23-2015, 09:46 AM   #3
Rewards Points: 3,512
It would help with a picture as suggested by Mike. Sometimes sediment build up makes it hard to unscrew the adapter from shower head. Spray some pb blaster or wd40, tap it a few times with the handle of a screwdriver, let in sit for awhile, and try again. Use 2 wrenches one on the adapter and one on the shower head.
If all else fails, they sell those adapters at any big box store and you can just replace it. Take the whole thing with you to match it up.
If I'm picturing this right, looks something like this; Just a suggestion. Others with be along with more suggestions/advice.
jmon is online now   Reply With Quote
How to Remove Broken Piece from Showerhead Pipe Cindy_Home Plumbing 14 12-27-2011 03:36 PM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
replacing slab, how to replace under stairs johnny331 Building & Construction 1 01-02-2009 07:57 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
