Replacing Sacrifical Anode Rod On Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 2 Post By hkstroud
  • 1 Post By HandyAndyInNC
Old 02-08-2019, 12:42 PM   #1
Rewards Points: 644
Replacing sacrifical anode rod on water heater
I want to replace the anode rod in my water heater.
I pulled out the water heater's anode rod to see if it was worth replacing or if the water is attacking the water heaters interior steel walls. (Water came with the house so i have no idea when it was last replaced.) Water heater is from 2012.
It seems to be replaceable at this point but I'm not really sure.
Anyone have any experience with this?
Thanks!!
jaketrades is offline   Reply With Quote
Old 02-08-2019, 01:24 PM   #2
hkstroud's Avatar
Rewards Points: 5,548
Re: Replacing sacrifical anode rod on water heater
Yes they are replaceable. You will need a 6 point socket and a 1/2" breaker bar. They are torqued down pretty hard. You may need assistance, one person to hold the water heater while another does the grunt work.
A pneumatic impact wrench would probably be best.
COLDIRON and jaketrades like this.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 02-08-2019, 03:41 PM   #3
Rewards Points: 644
Here's a pic of the rod. Is it damaged to the point where replacing the rod wont help?
@hkstroud - yup used a impact wrench. Pulled that sucker right off.....
Old 02-08-2019, 03:50 PM   #4
hkstroud's Avatar
Replace it. I was doing its job protecting the tank but now time to replace.
Harold,
Old 02-08-2019, 03:52 PM   #5
Rewards Points: 470
They come made from aluminum or other higher quality metal. I suggest that you use the higher quality metal. No one wants to have aluminum in their water.
Andrew
Handy Andy In Mt Airy NC
jaketrades likes this.
HandyAndyInNC is offline   Reply With Quote
Black smelly water Gradydane Plumbing 3 11-30-2018 08:42 PM
Whirlpool Energy Saver Water Heater Problem Thurman Electrical 53 10-30-2018 11:08 AM
New-ish electric hot water heater blowing fuses. roasted Electrical 33 01-11-2017 01:24 PM
Shopping for New Electric Water Heater Lots of Questions LeakyHawaiiRoof Plumbing 3 11-02-2014 01:18 AM
