Replacing An Old Pipe Bend And Slope - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 05-22-2016, 01:47 AM   #1
Rewards Points: 327
Question
Replacing an old pipe bend and slope
I am preparing to replace a section of extra heavy cast iron pipe that is cracked and goes into a bend that has a bottom that rusted away. I would like to know about the importance of slope. The bend looks unusual to me. It seems to be a 60 degree street going into a 45 degree street in a way that the horizontal run of pipe turns 90 degrees. The combination of the two bends to make the turn results in a slope that's probably a little less than 45 degrees since the 45 is somewhat tilted.
To replace the turn I have come down to two choices. Replicate what's there now or use two 45 degree streets (or a 90 long sweep) and a 22. The way it would work is the two 45s would act like a long 90 sweep and tilt slightly into the 22. So there would still be some slope at the turn but less than before at 22 degrees. It seems like it would be better to do that, but does it break code in NY to use that many fittings? How about the slope?
I checked NY state plumbing code but I couldn't find out the maximum pipe slope. I found this though which says 1/2" max:
Maximum slope of drain line? - InterNACHI Inspection Forum
Also does anyone know why it is hard to find really wide radius 90 degree sweeps for schedule 40/dwv PVC. Like the guy in this question I noticed at Home Depot that the long sweep wye is so much longer than a long sweep 90 and seems to have a wider radius as well. Though someone says in that question the long sweep 90 has a longer radius. Still, I compared them at Home Depot and the wye looks much longer.
Here is a pic of the section of pipe I will be replacing (after properly strapping of course) and a closeup of the bend.
Deck is offline   Reply With Quote
Old 05-22-2016, 11:34 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 164
Re: Replacing an old pipe bend and slope
If I were to rebuild that and trying to match existing elevations- I'd probably go with a 90 in the horizontal section rolled down with a 22 to meet the lower pipe. whether you use streets or not would depend on your elevations.
I was taught to have the 90 be the upper fitting when possible as it's more flow restrictive than 45 or 22- I would rather flow out of a 90 than into it.
If you want to replicate what is there- that's fine too. It's just a little tougher to get alignment when fitting together because the angles are odd.
When dealing with plastic you have 2 types of 90's for drainage- regular and long turn. Most jurisdictions want long turns when turning hor. to hor. and vertical to horizontal(base of stacks). 2 45's is considered equivalent to a long turn
Regular 90's are used for horizontal to vertical and toilet stubs.
A combo is only longer because it matches the pattern of a wye and 45 glued together.
Now, if you get into cast iron fittings- the language is different. For example- whats in your picture is called a 1/8 bend and a 1/16 bend.....(with a lot of bad aids)
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Deck (05-22-2016), gregzoll (05-22-2016)
Old 05-22-2016, 12:14 PM   #3
Rewards Points: 1,852
After you cut the cast iron hub out make sure you grind off the welded seam so it is smooth. You will also have to use a transitional coupling CI to PL on both reconnects at each end. Also since we cannot see what you have farther upstream I would make real sure you have a strong enough support system in place on the cast iron prior to making your first cut. Be very careful even skilled plumbers can lose a finger when something go's wrong because of the weight of the cast iron itself.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Deck (05-22-2016)
Old 05-22-2016, 12:29 PM   #4
Rewards Points: 6,652
Personally I would rip out all of that old Cast and replace it with CPVC piping. Looks like too many bandaids on it.
I do like the Zip Ties. Normally we use Marlin wrapped around a patch.
This is how we were taught for DC repairs. Not one has failed yet. http://www.dcfpnavymil.org/Stations/...al)16Jul13.pdf
The Following User Says Thank You to gregzoll For This Useful Post:
Deck (05-22-2016)
Old 05-22-2016, 12:34 PM   #5
Rewards Points: 327
Thanks for all the information but I don't understand why a 90 long sweep would have more restrictive flow? What I thought I was going for here is less restrictive by having a turn with a wider radius, that's why I thought it would be better than the 45 and 60. I read that the solids and liquids can separate in waste and that's why they only allow slope that's like less than 1/2" unless you're transitioning to vertical, so I thought less of a slope would be better.
And you're right about that 45 and 60, getting that to have a turn of 90 is very difficult it's like there's only a single way to do it and for all I know the elevation may not be exactly the same.
Thanks. The coupling I have is 'Everflow 15400CS 4" Heavy Duty, Husky Type, No-Hub Coupling With Colored Shield' from amazon, it does not say transitional, it says no-hub coupling. Will that be a problem you think? Here's a pic:
The strapping I'm going to buy is 20 gauge galvanized from zoro. Here's a pic:
The section I'm replacing is the section with all the bandaids. The pipe is disintegrating in that area for some reason. Why would you do it with CPVC instead of PVC? I thought the former was only for high temp water and this is waste line so I don't have to worry about that (I don't think).
Old 05-22-2016, 12:36 PM   #6
Actually all of it is failing. It rusts from the inside out. Once you touch one section the next one will fail.
Go along with a Screw driver and tap the pipe with the handle.
Old 05-22-2016, 12:49 PM   #7
Plumber
Rewards Points: 164
You are over thinking the angles and grade on the pipe.
LT 90 is code compliant and standard practice for decades. My code says a cleanout is needed after 135*- that's a 45 +90. If blockage was an issue, they'd ask for a cleanout at every 90.
Ideal grade on a drain is 1/4". Avoid more or less although 1/8 inch is allowed in certain situations. More than 1/4" and there is an issue of solids and liquid separation.
Rolling fittings at angles you show has nothing to do with the pipe grade.
And yes, CPVC is water pipe- not DWV. But Greg is correct on his opinion of your CI pipe. Check all of it. At worst- replace all the horizontal lines.
You want a coupling that specifically says PLas x CI. The two types of pipe have different O.D. A no-hub coupling will pucker on the CI side when tightened and not seal.
http://pascospecialty.com/flyers/proseal_couplings.pdf
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 05-22-2016, 12:50 PM   #8
http://pvcpipesupplies.com/cpvc-vs-pvc
Old 05-22-2016, 12:51 PM   #9
http://www.diffen.com/difference/ABS_vs_PVC
Old 05-22-2016, 07:24 PM   #10
That's a great coupling if your replacing with cast iron. But if your using plastic and cast iron you need a pro-flex transitional coupling. Our Mission brand transitional coupling. There is a size difference between the different pipes the transitional couplings take that into effect.
http://www.supplyhouse.com/Fernco-30...FZWMaQod6WQMWA
http://www.amazon.com/Mission-Rubber.../dp/B005I02KAA
Old 05-22-2016, 11:55 PM   #11
Rewards Points: 327
Thanks, I looked into Proflex. However I should clarify my cast iron pipe is extra heavy (XH) so its OD is the same as PVC. I checked and it's exactly the same, the OD is a hair's width over 4 1/2 inches.
I tested the Everflow no hub coupling on the PVC and it was difficult to get on, required quite a bit of stretch. I assume that's because it must be designed for service weight cast iron which has a slightly smaller OD. I can't find out if it would be acceptable to use in my circumstances under code for NY. I wrote the company several days ago to ask about specifications and I never heard back.
The ProFlex I would need is 3005-44 which is XH CI / PVC to XH CI / PVC. Home Depot sells P3005-44 which is a Fernco but the PlumbQuik brand, and otherwise they appear to be the same. I'm thinking about getting that. I wonder if there's a code difference because the brand is different. I would prefer the extra length with the 4 clamps like the one I have now, but I can't find anything like that for XH CI / PVC to XH CI / PVC.
Old 05-23-2016, 03:42 PM   #12
All Cast Iron is heavy. That is why they take it down with two people and chain cut it in sections as they take it down.
Old 05-23-2016, 04:23 PM   #13
Rewards Points: 327
Yeah but what I mean is the cast iron is a specific type marked on its hubs with XH for extra heavy and is slightly larger in OD than service weight cast iron. Though I picked up some of the service weight cast iron fittings at home depot and I'd agree they're all heavy.
TheEplumber likes this.
Old 05-23-2016, 04:48 PM   #14
His cast iron is the real old school stuff. No longer made.
gregzoll (05-23-2016)
Old 05-23-2016, 06:12 PM   #15
Just like the stuff in my house. This is when you ask one of the local school coaches to send you the football or wrestling team to help take it down.
How to shingle a roof with a change in slope? gtzpower Roofing/Siding 6 05-12-2014 05:43 AM
Pipe fittings and slope slkarns Plumbing 6 04-11-2012 09:06 PM
Is there a set drain slope when using a wet bar pump? ryan5068 Plumbing 2 03-08-2011 04:33 PM
