Replacing Insulation And Cover Plate Causes Fuse To Blow - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2015, 09:26 PM   #1
Rewards Points: 4
Replacing insulation and cover plate causes fuse to blow
If I leave the insulation and cover plates off the water heater, it works great. When I replace the insulation and cover plate the fuse on the left side blows. I'm thinking the isulation is pushing either the thermostat onto the inner metal tank too much or a wire is uncovered and touching the inner metal tank when the insulation is pushed on.
Any suggestions would be great.
inadvertant diy is offline   Reply With Quote
Old 05-13-2015, 03:36 AM   #2
Rewards Points: 3,454
Welcome to the forum. I agree with your reasoning. Makes sense. Did this just start happening? How old is water heater? Make and model?
Please post a picture with cover plate off. Thanks.
Have to troubleshoot a little more. Turn off main breaker to water heater and check for any loose or bad wiring connections and rule that out.
Others will be along with more suggestions.
jmon is online now   Reply With Quote
Old 05-13-2015, 09:55 AM   #3
Rewards Points: 4
Thanks for replying. It is a Giant 152ETE-3F7M 2010. I had been working on it a while ago. I removed the lower element at one point as a means of saving myself in hopefully $120 cartridge for my shower. The element wasn't the problem so I cleaned sediment out of the bottom of the heater and replaced the element. I replaced the insulation and cover plate. I don't think it was immediate, but the fuse blew. When I took of the plate there was condensation on the element and some rusting. I changed the fuse, tightened the screws in the element, and cleaned up the rust, and made sure the wires and screws were clean and dry. I left the insulation and cover plate off. It worked fine for a couple of months. No condensation and no rusting. I put the insulation and plate back on yesterday and the fuse blew.
Old 05-13-2015, 10:13 AM   #4
Rewards Points: 3,428
Condensation does not naturally occur in the vicinity of the element hatches of a water heater. Are you sure that the tank has not sprung a leak?
This part may be tricky since it is hard to tell when the lower element kicks on, but when it does, use a (wood) stick to gently press here and there in the lower element hatch area with the cover plate and insulation patch removed.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 05-13-2015, 05:58 PM   #5
Rewards Points: 1,942
Your tank may have a seepage leak prior to a full blow out.
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Replacing Wall Insulation from the Outside jazzywhit Insulation 7 06-04-2011 09:26 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
