Replacing Garbage Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2015, 11:50 AM   #1
Rewards Points: 2
replacing garbage disposal
I am replacing my badger insinkerator with a waste king garbage disposal. I have a composite granite sink. There is a rubber gasket to go under the sink flange to be used with stainless steel sinks. It says all other sinks require plumbers putty. I heard that you should not use plumbers putty with granite because it will stain. should I use something else & if so what? thanks!
VickieC is offline   Reply With Quote
Old 01-17-2015, 12:10 PM   #2
Plumber
TheEplumber's Avatar
Hi Vickie, welcome to DIY Chatroom.
Putty can be used against stainless steel, but not against stone. To be safe, I would use silicone in your case. Apply a bead to the bottom of the flange, press it into the sink hole then tighten from below.
Clean off excess silicon from the flange and sink.
As for the rubber seal- in my opinion it gets tossed regardless of the type of sink.....
By the way, I moved your question to the plumbing board. Maybe another plumber will come along with more tips for ya
The Following User Says Thank You to TheEplumber For This Useful Post:
VickieC (01-17-2015)
Old 01-17-2015, 05:18 PM   #3
Rewards Points: 1,938
Make sure it is 100% silicon and not water based silicon.
Garbage Disposal Wiring Charlie15 Electrical 1 12-29-2014 10:30 PM
Garbage Disposal Requirements BigJimmy Plumbing 6 05-01-2014 10:05 PM
New Garbage Disposal Not Secure rich0 Plumbing 9 11-11-2012 01:03 PM
Best Garbage Disposal ToeJoe Plumbing 1 01-16-2011 09:22 AM
New Garbage disposal draining slowly. yoeye82 Plumbing 1 12-10-2010 03:40 PM
