Replacing Garbage Disoposal Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2015, 09:34 PM   #1
Rewards Points: 20
Replacing Garbage Disoposal question
Hi Guys,
Messy disposal started leaking out the bottom and I figure I'll just replace it with piping. How hard a job is this? I looked and I figure I have to remove disposal, remove pipe attached to the side, replace straight pipe down. Anything else? I have it on a right hand side of double sink, an old Kitchen Aid. Thanks guys.
italo is offline   Reply With Quote
Old 11-26-2015, 10:01 PM   #2
ZZZZZ's Avatar
Rewards Points: 2,460
OK, I'll bite. Why not replace the faulty disposer? A basic 1/3 hp unit only runs about $70.
ZZZZZ is online now   Reply With Quote
Old 11-27-2015, 06:47 AM   #3
Retired Moderator
Rewards Points: 7,174
Sometimes it is easy---if the trap adapter is within reach or the new P-trap and angled correctly.
You will need: Sink strainer basket
plumbers putty
PVC tailpiece and tail piece washer
P-trap
Post a picture ----someone will help.
Old 11-27-2015, 09:48 AM   #4
Rewards Points: 20
Thanks. I'd like to get rid of the disposal because I don't really care for them, and this gives me a reason. Here's a pic of the situation. I also pretty much have a "standard" tool set, meaning no specific plumbing tools per se. Anything special I'll need outside of parts? Thanks again.
Old 11-27-2015, 12:22 PM   #5
Rewards Points: 20
Here's the lay of the land with the disposal out. Seems that the pipe will NOT go straight as I first thought. Di I need an "S" pipe? It's approx. 6" down but maybe 2" back - not straight at all. I even loosened the other pipes and tried to wiggle it around. Anyone have any advice? Thanks.
EDIT: I cannot get these pics to upload properly. The first is sideways and the other upside down.
Replacing Garbage Disoposal question-photo11.jpg   Replacing Garbage Disoposal question-photo22.jpg
Old 11-27-2015, 01:29 PM   #6
Tizzer's Avatar
Rewards Points: 148
The big box stores have flexable parts.
You'll need to still attach the DW hose and probably need a hacksaw to cut any pvc with.
*I* disable(remove) the disposal's switch in case the circuit breaker gets turned back on, the wires underneath won't turn live. I also avoid those cheap plastic strainers.
Tizzer is offline   Reply With Quote
Old 11-27-2015, 03:04 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 174
I would use an end outlet waste kit, slip joint tailpiece extension, new ptrap and perhaps a 45* DWV 45 and trap adapter to align to the existing trap arm. Of course you need a basket strainer as well.
Assemble the waste kit to the strainers, use the extension to get down to the proper drain height.
The cut off the drain arm to get the alignment you need using the 45
I've rotated your pictures for you. The 3rd image is an end outlet kit on a disposal I installed. Of course you are replacing yours so imagine a 90 there instead
Old 11-27-2015, 10:47 PM   #8
Rewards Points: 20
Thanks Eplumber - big, big help.
question about replacing knob and tube ocelli77 Electrical 2 11-24-2012 07:30 AM
Replacing siding - question about vapor barrier ChemistryisCool Building & Construction 3 11-13-2012 02:40 PM
Garbage Disposal Question Tizzer Appliances 1 10-09-2010 07:49 PM
Replacing Metal Ring Around Garbage Disposal in Sink julbox3134 Plumbing 2 09-15-2009 01:19 AM
question about replacing a shingle roof w tin Moparman Roofing/Siding 4 06-01-2008 12:45 AM
