Replacing Cast Iron With ABS - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2016, 02:57 AM   #1
Rewards Points: 1,414
Thinking about replacing (or having replaced) the old main cast iron stack on the right. The piece you see the bottom of as it enters the black elbow is a 45 degree Y with a leaded toilet flange coming in the top and the rest of the stack coming in at an angle from the wall over the foundation. The cast iron is from the 60s or earlier.
What is the right way to make this connection? Can the bottom of the Y or elbow be cut with a chain cutter or sawzall and a shielded coupling attached to ABS or PVC? Or does one need to drill and chisel out the old lead and oakum and use a donut connection where the pipe sections join?
What cutting and connection method is least likely to crush or damage the existing cast iron we're connecting to? (Don't want to replace the drainpipe through the foundation or crawlspace or yard or neighbor's yard, etc... if possible).
Tom738 is offline   Reply With Quote
Old 06-16-2016, 08:46 AM   #2
Household Handyman
Rewards Points: 1,412
Re: Replacing Cast Iron With ABS
Why are you wanting to replace any of this? In the photo I do not see any cracks or broken pieces. Cast iron piping is one of those things that fall under the old "IF it ain't broke, don't fix it".
The Following User Says Thank You to Thurman For This Useful Post:
Javiles (06-16-2016)
Old 06-16-2016, 10:46 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
That little area looks like a lot of grief.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 06-16-2016, 11:09 AM   #4
Rewards Points: 767
If you accidentally crack a fitting it might get ugly. I have used the sazall blades for cast iron and they work pretty good.
ct18 is offline   Reply With Quote
The Following User Says Thank You to ct18 For This Useful Post:
Tom738 (06-16-2016)
Old 06-16-2016, 12:19 PM   #5
Three reasons that make it seem appropriate: (1) toilet above was from the 50s on lead flange with 14 inch rough, and are looking to replace with modern toilet with 12 inch rough; (2) wall and ceiling are open upstairs so it's a relatively convenient time to re-do in-house cast iron rather than have it go whenever is least convenient; (3) upstairs cast iron looks a bit rusty, although not too insane.
odd cast iron retiredmgn Plumbing 13 02-12-2012 05:33 AM
Replacing cast iron with PEX-Al-PEX silvajus Plumbing 0 02-07-2012 10:17 AM
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 03:42 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
