Replacing Cartridge On Pegasus Kitchen Sink Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2014, 11:52 AM   #1
Replacing Cartridge on Pegasus Kitchen Sink Handle
Hi all. Bad cartridge in Pegasus 856-011 causing leak. See photos of handle. I've received a new cartridge from Pegasus, but for the life of me, can't seem to pop the top metal cap off from the handle. Any tips or tricks to remove the top cap so i can access cartridge?
dkian is offline   Reply With Quote
Old 06-15-2014, 08:39 PM   #2
Rewards Points: 3,220
Welcome to the forum dkian.
No photo came up. You need at least 5 posts to post pictures. Try introducing yourself a few more times. Then click on post reply, scroll down to manage attachments, and upload and post pics from there.
Turn off water to faucet, open and relieve any pressure. Try looking for a hidden allen screw around the handle, remove it and handle should lift off. Sometimes you have have to jiggle it a little, all models are a little different, (this is where a picture comes in handy). Once handle is removed, there is a lock nut or lock ring that has to be removed before cartdridge will come out. Replace cartdrige and reassemble in reverse order. Turn water back on and check for leaks. Please post pics when you can so we can better assist you. Thanks.
jmon is offline   Reply With Quote
Old 06-15-2014, 09:53 PM   #3
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Model would be nice if you have it, looks like they have quite a few kitchen faucets
Gregg M.
gmaint is offline   Reply With Quote
Old 06-16-2014, 05:48 PM   #4
Rewards Points: 1,860
Home Depot brand faucet... I tore out a tub shower one within a year for lack of parts.
Old 06-16-2014, 07:27 PM   #5
Rewards Points: 744
Usually, a rebuild kit (o-rings, springs, seals) is all that's needed...
Seattle2k is offline   Reply With Quote
Old 06-16-2014, 09:50 PM   #6
Not when they change parts constantly and no online presence or home depot parts available.
Old 06-24-2014, 10:55 AM   #7
Pegasus
Where did you find contact info for Pegasus? I have been searching online for days. The only number I find is for Home Depot and they do not have the part for this particular faucet. The problem I am having is that when I turn the handle to hot no water comes out....it just drips. Any advice is appreciated!!!
mariawill is offline   Reply With Quote
Old 06-24-2014, 03:35 PM   #8
Rewards Points: 18,794
Pegasus is a super cheap store brand.
Replace it with a Moen so you can get parts at any hardware, box store, plumbing supply.
Old 06-26-2014, 04:15 AM   #9
Rewards Points: 271
Pry the cap off with something thin and pointy like the tip of a pocket knife.
Older thread on Pegasus 856-011 http://www.doityourself.com/forum/pl...-required.html. It has a link to a PDF exploded diagram of faucet.
Druidia is offline   Reply With Quote
Old 09-17-2015, 03:50 PM   #10
Rewards Points: 2
Pegasist parts line
To speak to a human to order parts for your lifetime warranty for your Home Depot Pegasist faucet...1-877-5827-0313
mlafoy1@yahoo.c is offline   Reply With Quote
Old 09-17-2016, 11:03 AM   #11
Rewards Points: 2
Re: Replacing Cartridge on Pegasus Kitchen Sink Handle
I have a Pegasus two handle 67136 model series. The problem is the hot water on/off keeps change positions. Can anyone tell me what is causing this problem? Thank You
gem39 is offline   Reply With Quote
Old 09-17-2016, 11:47 AM   #12
Welcome to the forum gem.
You would be better off starting a new thread of your own rather than digging up a two year old thread. You will get better results. Just a suggestion.
Replacing Cartridge in mop sink faucet vabear Plumbing 6 03-18-2014 09:52 AM
Kitchen sink, stainless undermount or Trugranite undermount? DIY-Her Kitchen & Bath Remodeling 4 05-10-2012 12:18 PM
Replacing kitchen sink light fixture TrishaC Electrical 3 07-04-2010 01:14 AM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 06:07 PM
Replacing kitchen sink knob? Pikaia Plumbing 4 06-09-2005 09:43 PM
