Replacing A 1.25" Copper Sink Drain With PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2014, 05:01 PM   #1
Rewards Points: 126
Replacing a 1.25" Copper Sink Drain with PVC
Hi all - Happy New Year!
I'm demoing a small half-bath and would like to replace a 1.25" copper drain for the sink (I think it's copper) with PVC. The drain is tying into the vent stack pipe coming from the toilet.
What's the best way to do this? Here's a picture of the existing piping.
Sorry for the darkish picture. The pipe I'm referring to is the horizontal piece.
Thanks!
TeeRiddle is offline   Reply With Quote
Old 12-31-2014, 05:24 PM   #2
Rewards Points: 1,942
Unscrew it from the cast iron tee and thread a abs or pvc 1.5" MIP adapter in the hole . Use Teflon tape and pipe dope.
MIP Male Iron Pipe.
The Following User Says Thank You to Ghostmaker For This Useful Post:
TeeRiddle (12-31-2014)
Old 12-31-2014, 07:18 PM   #3
Rewards Points: 126
Sounds pretty straight forward. Thanks!
Old 12-31-2014, 07:30 PM   #4
Rewards Points: 18,976
Make sure you buy the adaptor that says 1-1/2-1-1/4 on the paper cap. There's two different washers included so it can fit 1-1/2 or 1-1/4 pipe.
Old 12-31-2014, 07:36 PM   #5
Rewards Points: 126
Will do, Joe. Appreciate the heads up!
Old 12-31-2014, 09:31 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 258
Hopefully the 4" tee is tapped for 1.5". Around my area you cannot get 1.25" drainage pattern fittings- only 1.5" and larger
Old 01-01-2015, 09:05 AM   #7
Make sure you use a 2 foot pipe wrench and PB blaster it first.
Replacing Old Sink Drain ko0olaidguy Plumbing 4 08-22-2013 07:32 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
sink drain exterior wall iskyfly Plumbing 11 02-04-2012 06:38 PM
Maximum distance of sink from drain? DIYHomeTheater Plumbing 0 06-14-2010 07:42 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
