Replaced Water Heater But Lost Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2016, 07:06 PM   #1
Rewards Points: 652
replaced water heater but lost pressure
I replaced a 20 year old 40g water heater with a 50g Rheem XG50T12DU36U0.
Due to the additional height, I had to add a 90 fitting to the cold and discharge side so I don't have to bend the tube too much. I don't see how these two fittings can reduce my pressure by so much.
I have a grophe shower head that spins with pressure, it no longer capable of spinning and the water is dropping out of it and not shooting out like it used to.
The pipe is old galvanize that'll be replaced shortly but I don't see how the new water heater can reduce my pressure by so much.
dannieboiz is offline   Reply With Quote
Old 05-25-2016, 07:41 PM   #2
Rewards Points: 16
Try disconnectimg your shower head and running the water maybe some sediment got in the line during the swap out, also check the water saver screen in your shower head for sediment, hopefully it's as simple as that. Good luck!
FullSwing is offline   Reply With Quote
Old 05-25-2016, 08:19 PM   #3
Retired Moderator
Rewards Points: 7,174
Re: replaced water heater but lost pressure
Originally Posted by FullSwing View Post
Try disconnecting your shower head and running the water maybe some sediment got in the line during the swap out, also check the water saver screen in your shower head for sediment, hopefully it's as simple as that. Good luck!
This is the most likely cure------------
If the hot water pressure is low every where in the house--check the shut off valve for the water heater---the old style gate valves sometimes fail to open fully ---and need replacing.
Old 05-25-2016, 08:25 PM   #4
Rewards Points: 652
both are great suggestions, I'll try that first. Just making sure that it isn't that new tank doing this. Copper pipe should be in place in the next month or so, so sediment isn't a major concern as all shower valves will be replace at the same time.
Old 05-25-2016, 08:32 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 898
Make sure the water trap heat nipples are not installed basackward.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-25-2016, 08:38 PM   #6
Rewards Points: 652
the original doesn't have a heat trap and I didn't add one and also read that if I have a recirc pump then I shouldn't be using one.
Old 05-25-2016, 08:42 PM   #7
Lord of Slums
Rewards Points: 1,974
I have had rentals lose water pressure simply by turning off the water. The galvanized pipes closed up from the sediment. Your problem is no surprise.
mj12 is offline   Reply With Quote
Intermittent Low Water Pressure Mystery bmbouter Plumbing 5 10-27-2015 04:54 AM
A Water Heater, an Outlet, a Cable and a Breaker Koldhammer Electrical 1 02-19-2015 04:43 PM
High water pressure spike (140 PSI) sidejobjoe Plumbing 2 01-28-2015 04:06 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
