Replace This Water Shutoff Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2016, 09:34 AM   #1
Rewards Points: 2
replace this water shutoff valve
Hi,
I need to replace this water shutoff valve as it is leaking when turned to the open position. this valve controls an outside spicket. I'm assuming I would just cut it out and replace with a new style valve but my concern is that the water pipe doesn't look like copper water pipe. it does look soldered though.
how should I go about replacing this leaking valve?
thanks
scottmik is offline   Reply With Quote
Old 06-30-2016, 10:04 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 172
Re: replace this water shutoff valve
Hey scottmik, welcome to the chatroom.
There are multiple hose bibs and pipe types installed. We need more detailed info in order to offer suggestions. Do you have a picture you could upload
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 08:55 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
