Replace Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By hkstroud
Old 10-11-2017, 08:28 PM   #1
Rewards Points: 172
I know I am supposed to turn off main water and turn off gas and then drain tank. But Does anyone know if I am supposed to open all faucets or not to drain the house lines prior to rolling out the old tank?
bobmane is offline   Reply With Quote
Old 10-11-2017, 08:54 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,596
Re: Replace Water Heater
Opening up a faucet on the upper floor will make the draining much quicker since it will allow air above the water and drain the lines at the same time.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-11-2017, 09:36 PM   #3
Rewards Points: 172
Only one faucet?
Old 10-12-2017, 12:07 AM   #4
hkstroud's Avatar
Rewards Points: 6,694
Stick a drinking straw in a glass of water. Put your thumb on the end of the straw and pull it out. See how much water comes out. Remove your thumb and watch how much water come out.
Same thing applies to the water heater and pipes. The water can't come out unless the air can come in.
chandler48 likes this.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 10-12-2017, 09:58 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 258
Originally Posted by bobmane View Post
Only one faucet?
Depends on the faucet. If it has a vacuum breaker it won't help.
Open one such as a tub.
Sent from my XT1650 using Tapatalk
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
