Replace Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2017, 11:18 AM   #1
Rewards Points: 660
replace tub drain
I would like to start using an old fashioned rubber plug for bathtub drain. So I took off the top of the one that was installed and was met with a stem that poked quite a ways up above the deck. What can get or do to use the plug of my dreams?
puttster is offline   Reply With Quote
Old 08-25-2017, 11:31 AM   #2
Rewards Points: 2,650
Re: replace tub drain
I believe that the stem sticking up should unscrew from the drain fitting. I believe it actually belongs inside the metal stopper but time has taken its toll.
bob22 is offline   Reply With Quote
Old 08-25-2017, 12:16 PM   #3
retired framer
Rewards Points: 15,846
I think this should help.
The Following User Says Thank You to Nealtw For This Useful Post:
Mike Milam (08-25-2017)
Old 08-25-2017, 02:24 PM   #4
Mike Milam's Avatar
Rewards Points: 324
Thank you! I haven't needed to know this before, but glad to now, just in case.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 08-26-2017, 03:30 PM   #5
Rewards Points: 660
Yes, luckily the stem is "D" shaped so the vice grip had something to grip.
Now, actually I would like to put a strainer in there to catch hair. The opening is 1- 5/8" I guess I need a strainer of the same size, maybe https://www.amazon.com/dp/B000VA6I32...a-306440160361
Old 08-28-2017, 01:23 AM   #6
retired framer
Plug and strainer, sits over drain. I think.
https://www.wayfair.ca/OXO-Good-Grip...a-152666031900
Old 08-28-2017, 05:34 PM   #7
Rewards Points: 898
I like this style:
http://www.homedepot.com/p/Watco-1-8...0-BN/206003355
BIG Johnson is offline   Reply With Quote
HVAC drain issues Ankylus HVAC 0 08-14-2017 06:35 PM
Condensate drain drawing enough vacuum to prevent drainage GoVols HVAC 6 07-10-2016 04:26 PM
Replace Galvanized Drain lines? Tom738 Plumbing 1 06-09-2016 08:05 PM
Shower drain in concrete should I replace? Jpatrick Plumbing 4 02-28-2014 06:03 PM
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 12:28 AM
