Replace Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2017, 05:30 PM   #1
Rewards Points: 254
Replace tub drain
In case you haven't noticed my spamming the board lately, I just bought a house.
I'm trying to tackle various projects one at a time. Today I was messing with a tub drain that wasn't holding water. I decided to replace the trip lever type with a toe click style. I bought this:
http://www.homedepot.com/p/DANCO-Tou...8981/202745113
So I removed the linkage from the old stopper, replaced the overflow trim piece and removed the old drain. The new stopper came with a gasket but it was not large enough to use. I reused the gasket from the shoe, put some plumbers putty around the drain and threaded it in.
Turned on the water and of course, now I have a leak where the shoe meets the tree. So I torque that down a little and check again. Now I am leaking at the shoe. So I removed the drain again, and roll some new putty in there and torque the drain a little harder.
You see where this is going? Sooo, in tightening the drain this time I broke the cross members and now I need to work on getting that new drain out to replace it.
My question though is what did I do wrong? I shouldn't be using a gasket AND putty under the lip of the drain correct? Should I try replacing the shoe where it connects to the tee?
JSDNJ is offline   Reply With Quote
Old 01-02-2017, 06:49 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 248
Re: Replace tub drain
Moved to plumbing.
Sounds like too much putty? Hard to tell from your description. But I would consider a new waste and overflow- not just the drain trim.
Old 01-02-2017, 07:17 PM   #3
Rewards Points: 254
Originally Posted by TheEplumber View Post
Moved to plumbing.
Most of the plumbing is newer. I don't think the overflow is an issue. I think maybe when I was installing the drain I disturbed the connection between the shoe and the tree?
Old 01-02-2017, 07:33 PM   #4
RRH
Rewards Points: 1,476
The trip levers usually cost a little more but worth it. People have a lot less drain blockage problems with that type. And don't have to keep replacing the toe stoppers that break a lot.
Anyway not what you asked.
No putty just the gasket underneath the tub. But you need another person holding the shoe in place so it does not move when you tighten the drain.
Never hurts to use a little sandpaper underneath an old tub to make sure a flat clean surface for the gasket to go against.
Also make sure you use enough putty under to flange for it to squeeze out.
RRH is offline   Reply With Quote
Old 01-02-2017, 07:35 PM   #5
Rewards Points: 254
Thanks for the tips.
I assumed I'd have less clogs with the stopper as opposed to the trip lever.
I thought I was upgrading
Old 01-04-2017, 10:53 PM   #6
RRH
Trip levers have the screen that catches a lot of stuff and makes the big difference.
Condensate drain drawing enough vacuum to prevent drainage GoVols HVAC 6 07-10-2016 04:26 PM
Replace Galvanized Drain lines? Tom738 Plumbing 1 06-09-2016 08:05 PM
Shower drain in concrete should I replace? Jpatrick Plumbing 4 02-28-2014 06:03 PM
Replace old kitchen sink drain or leave it? CoconutPete Plumbing 23 02-02-2012 01:20 PM
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 12:28 AM
