Replace Sump Pit With Basin? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2015, 12:40 PM   #1
Rewards Points: 263
Replace Sump pit with Basin?
Our home was built in '75. There is a sump pit which is approximately 16" x 24" and approximately 18" deep. There is one 3" pipe which enters the sump pit about 8" down. We don't see much water in it, during the wet months maybe 6" a week.
The entire thing is concrete, sort of a concrete box if you will with no cover. I'd like to replace this with a sealed basin. Is this something that is commonly done?
What would the process consist of? Break up the concrete bottom, plumb the pipe into the basic and fill around the basin with concrete? Any pictures of the process?
Thanks.
Here is my basin:
NickWa is offline   Reply With Quote
Old 02-11-2015, 12:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,238
Ayuh,.... Why would you want to do that,..??
just build yerself a cover for what's there, 'n working,....
Old 02-11-2015, 12:47 PM   #3
Rewards Points: 263
Well perhaps it is untrue, but I was told that the open pit was no longer considered "code legal" and while refinishing my basement, I would need to install a sealed unit?
Perhaps it simply needs to be covered?
Old 02-11-2015, 12:53 PM   #4
Bondo's Avatar
Donno the codes in yer area,....
The plastic basin will be nothing more than a plastic version of the concrete basin that's already there,.....
Old 02-11-2015, 06:07 PM   #5
Rewards Points: 3,416
A larger pit is better for the sump pump because fewer starts and stops occur all other things being equal. It would be undesirable to replace the concrete walled pit with a smaller volume plastic basin.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
The Following User Says Thank You to AllanJ For This Useful Post:
jomama45 (02-12-2015)
Old 02-11-2015, 08:02 PM   #6
Rewards Points: 1,932
Is this a storm sump or a toilet grinder sump? If its storm it just needs a cover.
Ghostmaker is online now   Reply With Quote
Old 02-12-2015, 08:55 AM   #7
Rewards Points: 263
It is simply a storm sump. I suppose by not to code he was trying to sell a sump remodel when a lid would suffice.
Old 02-12-2015, 05:26 PM   #8
The only reason you need a lid on it is to keep small children from falling head first into it. Sort of like the 5 gallon bucket pic with the kid in the bucket.
Who said it was not to code?
Old 02-12-2015, 05:53 PM   #9
Concrete & Masonry
Rewards Points: 518
It was certainly to code in 1975 when it was built, so it's still to code today. It's "grandfathered" in, regardless of any remodeling you'll be doing near it in the basement.
I understand why you'd want to cover/seal it though. IMO, .250" lexan with some gasket material works well, and it allows you to monitor the pumps and water level. You'll probably need to make it in 2 pieces to get around the pumps and pipes........
jomama45 is online now   Reply With Quote
The Following 3 Users Say Thank You to jomama45 For This Useful Post:
concretemasonry (02-12-2015), mj12 (02-12-2015), NickWa (02-13-2015)
Old 02-13-2015, 07:05 AM   #10
Rewards Points: 263
Yeah, I was considering replacing the pedestal pumps with submersibles and moving the piping closer to the wall. in order to make it easier to cover. This is in the back of our furnace room where we have lots of storage so I'd like to make it as unobtrusive as possible.
Sump pumps (indoor and outdoor) chrisificti0n Plumbing 13 10-15-2014 06:08 PM
Sump pump/radon davemax Plumbing 8 09-11-2014 07:53 AM
sump pump basin / pit installation question ipokrov Plumbing 3 01-03-2014 10:25 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Sump Basin Install Considerations Fire4Effect Building & Construction 3 08-05-2009 04:30 AM
