Replace PVS Stack (noise) With Cast Iron Or Spray Foam - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Yodaman
  • 1 Post By TarheelTerp
Old 09-03-2019, 01:03 PM   #1
Rewards Points: 106
Replace PVS Stack (noise) with Cast Iron or Spray Foam
Remodeling the kitchen and bathroom and have the chance to do something about the main toilet drain noise. The house is 30 years old and built with PVC stack instead of cast. I have some $$ built into the budget for this and am wondering if I should sprayfoam or replace with cast. Plumber suggested the sprayfoam, sprayfoam guys recommended the cast stack (no i am not kidding). Any thoughts? House has 3 baths (vertical) and a kitchen on the stack wall.
Thanks...
g
geenowalker is offline   Reply With Quote
Old 09-03-2019, 01:11 PM   #2
retired framer
Rewards Points: 4,690
Re: Replace PVS Stack (noise) with Cast Iron or Spray Foam
How much room do you have in the wall?
Do not use flat bottom gables with scissor trusses.
Old 09-03-2019, 03:15 PM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,918
It's difficult to make any changes down the road once you have a cast stack. I'm renovating my house and doing just the opposite, removing a cast stack and replacing with PVC.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 09-03-2019, 04:17 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
Originally Posted by geenowalker View Post
...and am wondering if I should sprayfoam or replace with cast.
How about Roxul (rockwool batt)?
Old 09-25-2019, 11:53 AM   #5
Rewards Points: 106
Bats do nothing for sound. Sound is controlled by the material density.
Old 09-25-2019, 12:18 PM   #6
Property Mgt/Maint
Rewards Points: 7,402
I would try the spray foam. There is no way in ell I would replace working PVC with cast iron. I have broken up, cut up, and cut out enough rusted and clogged CI to know that is not a great option.
Layer the wall with some type of sound board?
or............https://www.soundproofcow.com/produc...proofing-wrap/
Or all three, wrap, spray foam the cavity and use a sound deadening board.
MTN REMODEL LLC likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 09-25-2019, 12:59 PM   #7
MarginallyQualified
By this... I'll assume by this that you've never used Roxul.
You should remedy that.
Old 09-25-2019, 03:08 PM   #8
Rewards Points: 380
Agree on Ruxul. Insulated my main stack behind the master bathroom wall and space between the joists below the shower pan on the second floor. It provides significant noise reduction!
tdisss is offline   Reply With Quote
Old 09-26-2019, 12:05 PM   #9
Rewards Points: 106
We tried that first. Rockwool sent me to spray foam in the beginning.
Old 09-26-2019, 01:07 PM   #10
MarginallyQualified
However less than perfect Roxul Batts may be...
WHEN (not if) that wall is opened again
you don't want to have to deal with any glued down to everything material.
tdisss likes this.
Old 09-26-2019, 01:56 PM   #11
Rewards Points: 106
Was talking to these guys yesterday. Soundproofingcow.com and their quiet wrap kit.
Theoritically I could utilize both.
