Replace Packing On This Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2015, 06:28 PM   #1
Rav
Rewards Points: 898
Replace packing on this valve?
I have a hot water heater cold water supply shutoff valve that is leaking from the valve stem. This is an old NIBCO (globe?) valve. I've tightened the packing (smaller) nut a few times but it eventually leaks again. I've attached a pic. Does this look like the type of valve that I should be able to easily remove the packing nut and put a new gasket in? When we eventually get a new HWH within a few years we'll replace the entire valve with a ball valve, but I'd like to stop the leak for now without having to get a plumber out here just to solder on a new valve. Thanks.
Rav is offline   Reply With Quote
Old 10-20-2015, 06:38 PM   #2
Rewards Points: 18,976
Good luck with a that idea, time for a new ball valve.
Old 10-20-2015, 06:43 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,972
Should be simple. You don't even need to turn off the water main. Turn valve off. Hold the handle and loosen the nut off. Remove handle and leave valve in place. Remove nut. Install new packing and nut.
Use teflon packing string.
http://www.lowes.com/pd_239679-72906...ductId=3148461
The Following User Says Thank You to joed For This Useful Post:
Rav (10-20-2015)
Old 10-20-2015, 06:43 PM   #4
Rav
Rewards Points: 898
I appreciate the reply, Joe, but I'd like to understand why it's not a good idea in this case. I've replaced the packing gasket on angle stop valves, for example, and had no problem with that.
Old 10-20-2015, 06:56 PM   #5
Main reason is why a do a job twice.
Gate and globe valves always mess up and do not shut off totaly.
So you stop the dripping, then what, it still will not cut off the flow of water.
Rav (10-20-2015)
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
How to Replace shower shut-off valve Cindy_Home Plumbing 2 12-26-2011 03:04 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 07:04 PM
