Replace Galvanized Drain Lines? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-09-2016, 06:18 PM   #1
Rewards Points: 1,414
Replace Galvanized Drain lines?
If walls are open, should an old (20-60 yrs) but seemingly good condition metal pipe drain & vent (1.5 inch) be replaced with plastic ABS/PVC? Or is it likely to last for another twenty or forty years?
It is a 1.5 line straight up from the basement. If we should replace it, is it fairly easy to replace the part where it goes through the roof? Can we just use the existing pipe through the roof and connect with a fernco or shielded coupling, or will the plastic pipe not support a length of metal pipe?
Thoughts?
Tom738 is offline   Reply With Quote
Old 06-09-2016, 08:05 PM   #2
Rewards Points: 1,852
Re: Replace Galvanized Drain lines?
Galvanized drains tend to clog a lot more then the plastic DWV piping. Because of corrosion build up inside the pipe. I would suggest replacing it out the roof and install a new roof flashing they are easy to do.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
Tom738 (06-09-2016)
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Yet another rough in question - connecting drain lines LHB_Texas Plumbing 2 12-28-2014 09:00 PM
Cabinet removal when under sink supply lines through floor and drain through wall? mikegp Plumbing 20 10-12-2014 01:44 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
Crossing Drain lines bdaub Plumbing 1 05-28-2010 02:55 PM
