Replace 1/4 Turn Water Shut Off Valve PEX Tubing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2016, 01:01 PM   #1
Rewards Points: 56
replace 1/4 turn water shut off valve PEX tubing
The water shut off valve going to the toilet is stuck in the off position. I purchased a replacement valve but I'm having problems removing the broken one. PEX tubing is used and when I try to remove the broken one the tubing just twists. There is a decorative chrome piece covering the pex tubing making it very hard to get a hold of with channel lock. I have never done anything with PEX tubing before, it there a different way I should be going about removing it? Thanks,
sprtfan is offline   Reply With Quote
Old 02-14-2016, 01:19 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
picture would help...
WhatRnsdownhill is offline   Reply With Quote
Old 02-14-2016, 01:27 PM   #3
Rewards Points: 56
Here is a picture of the valve I'm trying to replace.
https://onedrive.live.com/redir?resi...nt=photo%2cjpg
Old 02-14-2016, 01:33 PM   #4
Rewards Points: 56
The chrome piece coming out from the wall is covering the PEX. It is plastic flexible tubing at least I guess. I assumed it must be PEX and is what is in the basement. Let me know if any other pictures would be helpful. Thanks
Old 02-14-2016, 01:36 PM   #5
ok, put an adjustable wrench on the big chrome nut on the pipe, and channel locks on the valve and unscrew the valve.holding the adjustable so it wont move.make sure water is off..now whether you can get the nut and feral off is another story, but if the new valve has the same threading, some teflon tape over the old feral will seal it and some pipe dope..
Old 02-14-2016, 01:41 PM   #6
Rewards Points: 56
Thanks, I'll give that a try.
Old 02-14-2016, 03:22 PM   #7
Rewards Points: 56
Got if fixed, thanks. I tried to unscrew the valve before posting but had enough resistance, I was afraid I was doing something wrong. The new part was able to use the existing nut and feral.
Old 02-14-2016, 03:34 PM   #8
outstanding....
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Sizing a dual shut off valve for a water line to fridge ericman Plumbing 10 08-19-2011 09:47 PM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 02:47 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 12:44 PM
