Repair Compromised Studs - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 11-27-2017, 05:28 PM   #16
retired framer
Rewards Points: 15,654
Re: Repair compromised studs
As you suggested cut it off and replace it and scab the joint.
I don't like those big holes drill in the jack and kings studs. I think I would pull the pipe out repair the wall and run the plumbing in the room, You have a sink or something going there that could be used to hide the pipe,.
Old 11-27-2017, 06:45 PM   #17
Rewards Points: 20
Originally Posted by JasperST View Post
Looks like the high bid got the job.
The job was so small we didn't even bother with bidding. It was just to connect the washer drain to utility sink drain. We had no idea he would botch it up so bad.
asingh is offline   Reply With Quote
Wood studs for glass shower enclosure jaketrades Building & Construction 1 04-30-2017 09:14 PM
Termite damage repair Idunnoaboutthat Building & Construction 8 02-20-2017 04:36 AM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 10:35 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
