Removing Wax Ring Residue - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2016, 07:13 PM   #1
Rewards Points: 5,614
Plumber left wax ring residue on, well, just about everything he touched. I'm not too concerned with the toilet surfaces but what would be recommended to clean it from the vinyl floor. Sudsy ammonia didn't get it.
Old 12-02-2016, 07:23 PM   #2
Property Mgt/Maint
Rewards Points: 8,184
Re: Removing Wax Ring Residue
one parts vinegar, 3 parts water, heat from the water or a hair dryer may help,
lots of elbow grease, good luck
Yodaman is offline   Reply With Quote
Old 12-02-2016, 07:32 PM   #3
Property Mgt/Maint
FYI - I stopped using wax seals a few years back. It's almost a pleasure picking up toilet with a waxless seal under it. If that's possible !!
Old 12-02-2016, 08:39 PM   #4
Rewards Points: 1,862
Any decent pine oil based cleaner will do it.
Old 12-02-2016, 08:43 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,754
Just like scraping the frosting out of the cake bowl....
MTN REMODEL LLC is online now   Reply With Quote
Old 12-04-2016, 11:41 AM   #6
Rewards Points: 2,074
Hair blow dryer. Heat and wipe when soft.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 16 08-27-2016 11:52 PM
Removing flange bolts prior to placing new wax ring Joe D. Plumbing 5 09-23-2014 11:31 AM
mapei 995 removing residue DBPOTTER Flooring 0 07-12-2014 06:57 AM
Removing wall mount sink connector OldHomeJen Plumbing 6 11-27-2013 08:45 AM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 10:31 PM
