Removing Shower Base From Basement - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By oh'mike
Old 09-24-2016, 11:33 AM   #1
Rewards Points: 2
Removing shower base from basement
Hi,
I have an old shower stall in the basement, the walls which were rusted and I removed. The base has a crack and I'd like to replace it. It appears to be glued onto the foundation below (which is raised), and the outgoing pipe looks like cast iron? Is there any way to remove the base without breaking up the mortar and redoing the drainage pipes?
Removing shower base from basement-img_1511.jpgRemoving shower base from basement-img_1512.jpg
Mo2016 is offline   Reply With Quote
Old 09-24-2016, 04:05 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Removing shower base from basement
You will want to replace the pipe and P-trap any way--its old and corroded--
That is not as big a job as many think---and well within the realm of DIY--
So--get out your BIG hammer--stuff a rag into the pipe--and crack that old base out of there---
SHR Plumber likes this.
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 09:39 PM
Plastic shower base and concrete / leveling issue JoTeeBee Kitchen & Bath Remodeling 2 06-17-2011 07:46 PM
Basement Shower Problem carolfleming Flooring 1 03-17-2011 07:17 PM
Removing an old shower pan kvn Kitchen & Bath Remodeling 3 10-24-2010 08:23 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
