Removing Plumbing To Install Sheetrock - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree13Likes
Old 07-14-2017, 06:02 AM   #31
hkstroud's Avatar
Rewards Points: 6,694
Re: Removing plumbing to install sheetrock
Clean that joint with wire brush and post close up of it.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 07-15-2017, 06:47 AM   #32
Rewards Points: 960
Could the steel nipple and cast iron nipple have fused together?
Here's a closeup pic.
jaketrades is offline   Reply With Quote
Old 07-15-2017, 07:47 AM   #33
ZTMAN's Avatar
Rewards Points: 624
Don't know if you hit the joint with PB Blaster, it looks pretty dry. If you have and it did not work, Locktite has a product I have used in the past called Freeze and Release. Spray it on the male end and it shrinks a little. The only time I needed the product, it worked when other products failed
jaketrades likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
jaketrades (07-15-2017)
Old 07-15-2017, 03:24 PM   #34
hkstroud's Avatar
Doesn't look like a lead joint, at least not to me.
Harold,
Old 07-15-2017, 05:45 PM   #35
Rewards Points: 960
Tried regular wd40. Just bought a can of pb blaster which I'll hit it with tonight.
Old 07-18-2017, 02:01 PM   #36
Rewards Points: 1,054
Use a torch and get it nice and hot. Try the melted wax method. Another thing that helps is vibrations for smacking it with a hammer. The issue I see is that the vent hub is not strong enough to resist the force required to loosen the corroded pipe. I would not waste too much time on it. Cut it flush with a grinder wheel or a sawzall. Then I'd use a small metal blade in a sawzall to cut the inside of the cut off pipe 3 places 120 degrees apart, to the top of the threads. Use a cold chisel to try to break the pipe stub into 3 pieces and knock them out of the vent hub. If that doesn't work, cut to the bottom of the threads. Then use a tap to chase the threads. Use penetrating oil while cutting. Use pipe dope when replacing the cut pipe.
clarenceboddick is offline   Reply With Quote
The Following User Says Thank You to clarenceboddick For This Useful Post:
jaketrades (07-19-2017)
Old 07-18-2017, 03:18 PM   #37
retired framer
Rewards Points: 15,194
Don't force it, get a bigger hammer.
sheetrock install B howell Drywall & Plaster 2 04-29-2011 11:46 PM
floor joist has been cut in too to install plumbing gunslinger7966 Carpentry 10 04-23-2011 03:12 PM
New dishwasher install -- plumbing help kb01 Plumbing 3 04-23-2011 11:51 AM
How soon can I install Masonite doors after sheetrock? cej22 Carpentry 6 07-09-2009 08:11 AM
Removing a chipped tile on a current install JAN GM Remodeling 3 07-07-2009 05:55 PM
