Removing Plumbing To Install Sheetrock - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree13Likes
Old 07-12-2017, 11:51 AM   #16
Rewards Points: 960
Re: Removing plumbing to install sheetrock
Originally Posted by Ghostmaker View Post
Are you in a high rise building?
Over 3 stories.
jaketrades is offline   Reply With Quote
Old 07-12-2017, 11:54 AM   #17
Rewards Points: 960
Originally Posted by TheEplumber View Post
Yes, remove the nipple and replace.
You will probably need a back up wrench on the tee hub. A couple 18 or 24" wrenches will do it
Trying to crank it off but no luck. Don't want mess up the rest of the dwv. Is there thread breaker you guys recommend? Or propane torch?
On a separate note when I thread on the new nipples do I need to use plumbers putty or plumbers tape?
Old 07-12-2017, 05:41 PM   #18
retired framer
Rewards Points: 15,472
You have clamps above and below take it out and buy a new one.
Old 07-12-2017, 05:56 PM   #19
Rewards Points: 960
Oh buy new threaded sanitary tees?
Yeah I guess I could do that. Was hoping for a less expensive solution.
Old 07-12-2017, 06:37 PM   #20
retired framer
Time is money too.
jaketrades likes this.
Old 07-13-2017, 10:33 AM   #21
Rewards Points: 960
It's a two way thread sanitary tee - so pulling it out will a pain.
Hit it with map gas no luck. Maybe a longer wrench or pipe extension?
Nealtw likes this.
Old 07-13-2017, 11:00 AM   #22
ZTMAN's Avatar
Rewards Points: 628
Did you put penetrating oil in the joint?
If not, I would spray some in the joint and let it do its work.
Sometimes giving it a clockwise turn, and then counterclockwise will break it loose.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
jaketrades (07-13-2017)
Old 07-13-2017, 11:19 AM   #23
retired framer
If you can't get it you could cut it and join to it with fernco coupling.
The Following User Says Thank You to Nealtw For This Useful Post:
Old 07-13-2017, 02:06 PM   #24
hkstroud's Avatar
Rewards Points: 6,694
Put your foot on it and show it who is boss.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 07-13-2017, 02:58 PM   #25
Rewards Points: 960
I tried but I didn't go all out. If I crack something back there I'm fukd. I'd rather cut off the bad piece with my angle grinder.
Old 07-13-2017, 08:46 PM   #26
Rewards Points: 1,942
Try to tighten then loosen it usually will work for some weird reason.
Ghostmaker is online now   Reply With Quote
Old 07-13-2017, 08:48 PM   #27
Rewards Points: 960
Tried that as well. Nothing
Old 07-13-2017, 09:25 PM   #28
Plumber
TheEplumber's Avatar
Rewards Points: 258
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 07-13-2017, 10:22 PM   #29
hkstroud's Avatar
Just realized , that joint is probably a lead and oakum joint, not threaded.
Take a wire brush to it so we can see.
Harold,
Old 07-13-2017, 11:02 PM   #30
Rewards Points: 960
Great video. Not sure I'm confident I won't mess up the santee in the process. Then I'm in a world of hurt.
sheetrock install B howell Drywall & Plaster 2 04-29-2011 11:46 PM
floor joist has been cut in too to install plumbing gunslinger7966 Carpentry 10 04-23-2011 03:12 PM
New dishwasher install -- plumbing help kb01 Plumbing 3 04-23-2011 11:51 AM
How soon can I install Masonite doors after sheetrock? cej22 Carpentry 6 07-09-2009 08:11 AM
Removing a chipped tile on a current install JAN GM Remodeling 3 07-07-2009 05:55 PM
