Removing PEX From Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2015, 11:44 AM   #1
Rewards Points: 18
Removing PEX from valve
Hi -
I am trying to replace a 4" piece of 1/2" PEX. We cut it and removed one part without problem. The other 1" piece is stuck on a valve and we cannot pull it off. We were able to remove the clamp, but the PEX is still really tightly stuck to the pipe that protrudes from the valve. Any ideas of how to get it off without ruining the valve?
Also, I'm just wondering -if it is so tight now - am I going to be able to easily slip on the new PEX?
cindes is offline   Reply With Quote
Old 04-30-2015, 11:58 AM   #2
Rewards Points: 19,008
Got a picture of the valve.
We have no idea what type you have.
Crimp ring, push type?
cindes (05-01-2015)
Old 04-30-2015, 12:09 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 302
Gradually heat the piece of pex with a heat gun or small torch until you can pull it off- go easy with the heat...
You can also gently slice down the fitting with a razor- be careful not to cut into the barbs
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-30-2015), cindes (05-01-2015)
Old 04-30-2015, 12:43 PM   #4
Rewards Points: 18
Photo attached. Don't have a heat source, but could buy if needed. And can you be more specific about "cut down the fitting"? Not sure what that means exactly :-/ Cutting through the PEX itself has been really difficult!
P.S. I am not the one who cut the PEX right at the edge of the valve.
Old 04-30-2015, 01:01 PM   #5
FIDO...
Rewards Points: 325
From the pic, I see you are already using some sharkbite connections... Have you considered replacing that old gate valve altogether with a new 1/4-turn ball valve? Sharkbite makes them, and they should be stocked at your local HD.
Just another possibility....
Cheers, Chris
Chris130 is offline   Reply With Quote
The Following User Says Thank You to Chris130 For This Useful Post:
cindes (05-01-2015)
Old 04-30-2015, 02:06 PM   #6
A utility knife should go through that easy.
No ossilating tool?
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Old 04-30-2015, 02:09 PM   #7
Rewards Points: 474
I use a knife all the time and just cut it off … just make sure that it is nice and sharp
BrowneBearLLC is offline   Reply With Quote
Old 04-30-2015, 02:26 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,324
Ayuh,.... Score it with a utility knife, 'n grab it with a pair of plyers to pull it off,....
If ya wanta heat it, a bic-lighter would work on that small fittin',...
The Following User Says Thank You to Bondo For This Useful Post:
cindes (05-01-2015)
Old 05-01-2015, 01:27 AM   #9
Rewards Points: 352
Use a dremel tool
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
cindes (05-01-2015)
Old 05-01-2015, 02:55 PM   #10
Rewards Points: 18
Thank you! Lighter worked
I held a lighter to it for a minute or so, and it came right off!
Thank you! Cheapest, easiest option by far.
Old 05-01-2015, 03:07 PM   #11
Restoration professional
Rewards Points: 302
Every time I do this, I wonder if I've damaged the barbs. Has anyone ever had a failure by scratching the brass too deep?
halliwellc is offline   Reply With Quote
Main Water Shutoff Valve problem obadran Plumbing 16 12-10-2012 11:45 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
