Removing Old Drain And Installing Garbage Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2014, 09:00 AM   #1
removing old drain and installing garbage disposal
Hi all, thx again for the help w/ the ejection pump
altho since I installed it, at random times it runs and pumps water out, I wonder if my check valve is bad? I bought a new PVC sewage check valve but havent swapped it out yet, on the to-do list for this weekend
anyway, i have the attached pic here of current drain / setup. i looked at a few videos online and most drains seems to have a locking screw nut, i dont see that here? what would be the best way to get the old drain off and how much pressure do i have to use to pop the old one out that I assume has plumbers putty on it?
https://www.dropbox.com/s/wcosnsho0cd7val/photo-3.JPG
once I get the disposal drain and the disposal actually mounted, from the basic knowledge I have it looks like I should just be able to loosen and swivel the trap to align with the new outlet of the GD
I havent opened the box yet but I would imagine it would look like the pic on amazon
http://ecx.images-amazon.com/images/...L._SL1500_.jpg
what would I have to get, just a 1 1/2" straight pipe, plus a few washers, and whatever you use to compress the washer onto the pipe / pvc (i dont know the lingo for it)
let me know
enigma91884 is offline   Reply With Quote
Old 01-09-2014, 09:12 AM   #2
Rewards Points: 3,130
Yeah, most disposals look something like that Amazon picture. If you have a dishwasher, its drain goes to the smaller connection on the disposal. That connection is more than likely plugged, so you'll have to knock the plug out if a dishwasher is to be connected.
Old 01-09-2014, 04:02 PM   #3
ok, great, thanks, this seems easy -- almost too easy, lol
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 09:13 PM
installing garbage disposal with standard drain davidorr Plumbing 2 07-18-2011 07:48 PM
Help fixing a leak and installing a drain trap. papageek Plumbing 0 12-01-2010 11:23 AM
Installing reverese osmosis filter system - with a garbage disposal? J187 Plumbing 8 01-07-2010 08:46 PM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
